turn signals
wombat_87
turn signals
ive just bought a 1993 zx9r and i want some flush finish clear indicators for it but i cant find any for that model
can any 1 help me out and im having the same problem trying to find a rear fender iliminator as well... please help
- red_dave
- Team Kuda
Re: turn signals
Not sure if it will work but, my old 02 636 had a similar undertail to yours and i ended up cutting it off just below the number plate bracket. I then mounted the number plate using the bottom holes which sat the plate just under the reflector under the tail light... If that makes sense...
Anyway, good luck
Anyway, good luck
- Six Addict
- Pinchy
- Bike: Ducati
Re: turn signals
it should have something similar dave...
hey wombat u can just cut the original as required or try googling a company called targa... they have heaps of eliminators... even for a 93 model id bet....
- red_dave
- Team Kuda
Re: turn signals
Your's definately will Owen...
I'll be round with a hacksaw shortly - make sure the beer is cold!
wombat_87
Re: turn signals
[quote="red_dave"]Not sure if it will work but, my old 02 636 had a similar undertail to yours and i ended up cutting it off just below the number plate bracket. I then mounted the number plate using the bottom holes which sat the plate just under the reflector under the tail light... If that makes sense...
yeah i understand wat your saying ill have look at doing that if i cant find some other ways...thanks for the idea
- Nosferatu
Re: turn signals
have a look here for the fender eliminator (1994 ZX9R)
http://www.morepowerracing.com.au/produ ... re+Details
and here for flush mount indicators
http://www.amcmotorcycles.com.au/index1.html
http://www.flyncycle.com/acatalog/FAIRI ... ATORS.html (i couldn't tell if this mob ships overseas)
hope this helps
Marty
hope this helps
Marty
