alas poor clutch, I will miss you
Well, my clutch has finally decided to go to mechanical heaven. I knew it was on the way out due to the frequency of adjusting but thought it would be ok until I got the spare bike but no... time was not on my side.
Sitting at the lights in nuetral, click into first and instantly jump forward and stall... "what the..?", back into nuetral, make sure clutch is in, start, click into fir... BAM jumps forward and stalls. Oh well, probably just busted the clutch cable. Roll her off to the side of the road. Jump off and take off the leather, helmet and gubbins... check the cable at the engine end... hmm seems ok. Give it a yank and hear the clutch handle click back... uhoh. That means something IN the clutch is bust. Oh well it's a bummer but it's not like i haven't been expecting it to go. Manage to find a bike transporter that will pick up the bike at 8:30pm, stoked as I was not liking the idea of leaving her on the street all night.
So this weekend will be taking off the engine cover and checking out the damage, stay tuned for greasy pics. Anyone got any hints and tips they want to share before I get my hands oily?
Re: alas poor clutch, I will miss you
wear latex gloves
- andrew.k
Drink plenty of beer
Mechanics & alcohol go hand in hand
- Nanna10r
- Team Ninja
Supercheap $15 Breaker bar.
Clutches are P.O.P. to replace. I'd probably recommend tossing in a Race kit (3 thicker springs, big whoop) but as your Scoot isn't listed in your profile I'll hold off on that one.
Oh I forgot, Don't overtighten anything putting it back together. Use a "Yappa (torque) wrench" if you have one.
have fun. Nanna
have fun. Nanna
- mike-s
remember to firstly soak the new plates in oil overnight first, then put the plates and basket in in exactly the right order and with all the plates facing the right way up, blah blah blah, otherwise the stupid thing wont work and you'll have to take it all out again!
RIghto. Had a reasonably successful weekend. As Pontikat correctly pointed out... I never thought there was going to be much drama involved in dismantling this. I have taken a bunch of pics just in case any newbies want an illustrated guide to the bits and bobs. And yes, there was beer on hand.
Firstly you need to get the right hand side bodywork off and also the bellypan. The right side is retained by 7 screws, 3 normal sized allen key bolts and then 2 larger bolts found just near where your knee would sit and one down by your foot.
click for biggah!
Undo all the bolts and I suggest bunging them into a ziplock sandwiche bag and writing on there what the nuts are for. Once all the screws are out on that side you can remove the middle body panel. There are three plastic tabs as shown in the picture below, carefully unhook these and another tab at the bottom front of the middle piece where it meets the darker grey section.
click for biggah!
Now go around to the other side and undo the remaining bolts attached to the bellypan. You do NOT have to remove the left side middle piece... once all unbolted the bellypan should drop down as one piece. Slide this out and place off to one side where you are not going to tread on it. Sounds retarded but why risk it?
You should now be looking at the nude right side of the engine.
click for biggah!
I had already unhooked the clutch cable but if you haven't already, now would be a great time to be disconnecting it. You can see in the following shots the routing of the cable around the engine and that the clip connects onto one of the coolant hoses.
click for biggah!
The fun part (read messy if unprepared) is next on the cards. It's prudent to have a oil change pan underneath the bike for this bit. Slowly undo each of the 10 bolts that hold the clutch cover in place, I would advise starting at the top and working your way down. Once the bottom is loose you'll get a nice stream of engine oil running out... if you heeded my advice you will now have an oil pan filling with oil, if you didn't you will now have oil generally spilling all over the garage floor and more than likely all over your shoes. IMPORTANT! Take note of where the bolts came out of as there are 3 different sizes. There are 4 long ones, 1 medium one and 5 small ones. I noted them down but I didn't take a shot of my crudely drawn pic, i might bung that in later.
click for biggah!
Gently pull the clutch cover off and set aside somewhere where you won't a) scratch the surface of the case and b) where the oil from inside the cover won't leak onto something valuable ie don't place it on the deed to your house or your birth certificate... i recommend paper towel personally. You should now be looking at something similar to the pic below:
click for biggah!
You can have a look at the clutch cover now and I've taken shots to show where the washers and that should go for the actuator. Mainly for reference
click for biggah!
If you are lucky, like i was, you'll be able to undo the 6 allen bolts holding the clutch plates in place. Try and undo them evenly, I don't think that it's important but I figured I might as well let out the tension on the springs gently.
click for biggah!
Again, mainly for reference, I have noted how the washer and springs sit together in the clutch. This is obviously the same for all 6 of the spring/nut/washer combos.
click for biggah!
Remove the alloy plate holding all the clutch plates in the basket.
click for biggah!
Enlist the help of a friend to take pictures while you gently remove all the clutch plates from the basket in one lot. Again, the pic is for reference and I noticed something wrong here as well. According to the workshop manual the thicker spring plate should be the first thing in the clutch basket but for some reason whoever reassembled my clutch last time stuck a friction plate in the first... go figure. Can anyone confirm whether this is right/wrong?
click for biggah!
You can see the gunk buildup from the friction plates getting worn down in the gantries surrounding the clutch basket
click for biggah!
Just a quick shot of the bearing that sits in the clutch face plate
click for biggah!
Some more shots of the gunk from the friction plates, this time collecting on the inside of where the clutch springs sit
click for biggah!
Most of the friction plates still had a good deal of meat on them, as you can see on this particular plate:
click for biggah!
But two of the plates were completely smooshed and had barely any friction surface left... you can see the carnage in the below two shots:
click for biggah!
Now I was expecting some catastrophic thing to instantly draw attention to what had actually gone wrong. Looking at the two damaged plates didn't gel with what I had experienced... I hadn't noticed any clutch slippage or anything leading up to the stalling... sure my clutch was on the way out but when things wear out they then to go gently and this was working...working... NOT WORKING. So I consulted the workshop manual and after looking back over my pics I found the issue. The spindle that comes out of the clutch and hooks into the actuator... compared to the one in the book mine appear to be missing the end. This is definitely in keeping with what I experienced. So I'm going to bung in a new clutch anyways since I already have the bike apart and I'm looking to keep her for a long time... and I need a new spindley thing. The only bummer is that I'm going to have to drop the sump to find the chunk of metal that broke off the end of the spindle... which in turn means removing the exhausts since I can't drop the sump with the exhausts in place.
So until my next update... if anyone has some hints and tips bung em up... otherwise... as you were
click for biggah!
click for biggah!
click for biggah!
click for biggah!
click for biggah!
click for biggah!
click for biggah!
click for biggah!
click for biggah!
click for biggah!
click for biggah!
click for biggah!
click for biggah!
click for biggah!
click for biggah!
click for biggah!
- stuartzx6
Very nice pics mate.
I am looking at changing over my clutch plates soon so this might help me abit.
Stuart
Stuart
Stuart with a 05 ZX6
Well, my parts... well. 1 part is on back order from the land of the Rising Sun. Initial estimates were that it would be here in time for Christmass but looks like that's failed. So I'm looking at Jan 3rd. Also the springs for the clutch kit are also on back order so they are due at the start of Jan as well. So until then the 10 stays up on a stand...
Sorry to hear about the delay on parts, but I have to say 10/10 for the teardown pics & descriptions
I am going to suggest this post should go in the how to section when you are done
- Smitty
robracer wrote:Sorry to hear about the delay on parts, but I have to say 10/10 for the teardown pics & descriptions
+1
- Smitty
just curious...no special tools used to hold the clutch basket
while undoing it?
while undoing it?
Nope, no special tools. The clutch held itself in place, surprisingly. Unfortunately I know that this will not hold true when re-assembling the clutch so hopefully my local Kwaka shop will either let me borrow the required tool with a deposit or sell me one that won't cost the earth. Turns out my father's torque wrench was halfinched by a rather dispicble so-and-so so I need to get a new one of them as well. Sidchrome hopefully... since most of my tools are already sidchrome.
- kwaker750
Thanks for posting up the pics and the report.It is always interesting to see any problems that other bikes have in case it happens to our own bike.
I am interested in the broken spindle part that you need.Can you post up a pic of the broken bit and the new bit when you have them?
Cheers.
Cheers.
Let The Good Times Roll.
Peter.
Peter.
Well... as you might possibly guess, the parts STILL haven't arrived. The spindle has arrived from Japan, it actually arrived quite a while ago. Apparently Barnett fucked up when it came to part numbering or something. I'm calling up on Tuesday since it's been a fortnight since I last checked in but I'm pretty peeved about the whole thing. Thankfully I had bought a second bike just when the clutch went so I still have transport... if not for that I would've been well screwed since I don't have a car (or car license for that matter).
As news comes in I'll update.
Mid-Feb... or maybe even late Feb...
3 months. 3 FSCKING MONTHS!
