04-05 ZX10R Shift Light Fix!!!!!!!
Troy Pearson
Post by Troy Pearson »
Hi all, I'm O.S at the moment but will be home over Xmas and will be machining up some Shift Light Fibre Optic lenses.
I have some fibre optic cable 10mm O.D. that I think will do the job nicely!
I think this will not only fix the Ten's but the Z1's aswell, correct me if I'm wrong!
I'am pretty confident this will enhance the existing light on the standard dash without the need to glue, rebuild a dash or change any globes.
So if you are a little tight on money this will be your ticket, that is if you want a light to look at you!
I would appreciate any feedback, either way, once I have made one up I will post the results on this page for everyone to look at!
Cost of the little buggers is going to be a measily $10. Easy, round figure!
Troy
Re: 04-05 ZX10R Shift Light Fix!!!!!!!
z1000's dont have the shift light. they have 2 blinker lighhts. well thats the 03-06 one anyway.
maybe the new one has a shifty
