Oil-leak
- Team Monster
Oil-leak
Hey guys, just got back from a run down the coast and noticed a streak of oil on the left hand side fairing.On closer inspection with a torch theres oil everywhere from just above the headers enough to coat the whole front of the motor, hoses and headers.Tried to take a pics but didnt turn out real good.Any ideas?I'm kinda hoping its just a rocker cover gasket.BTW its an '07 ZX6R.
Also should be ok to ride it the 10k's to aitkens yeah?And does anybody know if they are open tomorrow or are they on hol's?
Chees Dave...
Chees Dave...
- Slow and wobbly
- Bike: Scooter
Re: Oil-leak
07 kawasaki is just the same as a 63 Holden. So long as the oil level is kept up it should go anywhere.
- Team Monster
Re: Oil-leak
Your on a roll tonight wobblesSlow and wobbly wrote:07 kawasaki is just the same as a 63 Holden. So long as the oil level is kept up it should go anywhere.
- Team Naked
Re: Oil-leak
If you have an oil leak start looking for a triumph to go with it, they're notorious for em..
Re: Oil-leak
- Slow and wobbly
- Bike: Scooter
Re: Oil-leak
Nothing on Teev, just amusing myself.DISCO wrote:Your on a roll tonight wobblesSlow and wobbly wrote:07 kawasaki is just the same as a 63 Holden. So long as the oil level is kept up it should go anywhere.![]()
Clearly some don't understand my way of amusement
Too easy.
- Team Monster
Re: Oil-leak
Could it be from the wrong viscosity oil?Only thing done recently was an oil and filter cange.I checked the filter and its clean,plus its on the side of the bike....
- Team Naked
Re: Oil-leak
Have you done the oil filter/cap up tight? Wrong viscosity oil won't leak, just might ping a bit.
- Team Monster
Re: Oil-leak
Yeah both are tight was done by a mechanic, and no ping.Thats why I'm thinking a gasket...mick_dundee wrote:Have you done the oil filter/cap up tight? Wrong viscosity oil won't leak, just might ping a bit.
- Team Naked
Re: Oil-leak
Seems a bloody young bike to be doing gaskets already.. but i'm not a mechanics arsehole so spose it's possible, just thinking that I used to own a ZZR600 96 model and now a 98 model 9 and neither have ever done any gaskets...
- 6maniac
- Bike: Z750
Re: Oil-leak
Dave, it's Karma (because of the Gixxer vid).............HTFU!!!
Re: Oil-leak
check you oil level isnt over full.
i had a bit too much oil in my 10, and on atrackday it started to weep out the rocker cover gasket.
i think madkaws did the same. but only really happened at the track, where the revs are high for 15mins at a time sort of thing.
check you can see air in the sight glass. should be a about 2 thirds full on the glass. when the bike is upright.
- Team Monster
Re: Oil-leak
When i got the bike back (after the last track day) the level was high.I noticed upright the sight glass was full (no gap) but on the stand about 3/4.It was about a 300k run I went on when i noticed when i got back.Could it really just be too much oil?Will dumping some fix this or will it need another gasket?
Cheers Dave....
Cheers Dave....
- Team Monster
Re: Oil-leak
Shit Ron if its Karma shouldn't your bike have exploded by now!!!6maniac wrote:Dave, it's Karma (because of the Gixxer vid).............HTFU!!!
- 6maniac
- Bike: Z750
Re: Oil-leak
Don't look pretty....still running.....no oil leaks. What do I win ?
