Ive been looking through posts and noticing some people going from a 190 to a 180 rear on various bikes. I read a MCN (?) article where a french guy was racing a Z1000 and the first thing he did was change to a 180 rear. I have some good ex track rubber in the shed 120 and 180 rears though but i thought bugger it Ill throw them on my Z1000 next week and see. Ive read it speeds up turns etc. Has anyone out there done this ? a first hand opinion would be better than here say! just incase im doing the completly wrong thing.... I may miss the wide arse rear end tho
180/55 rear on Z1000?
- ventura01
Hey all,
Re: 180/55 rear on Z1000?
Wattie did this from memory, said it was no where as good as the 190..?
- JetPilot
I did this on my ZX9, Yes it turned in better but straight line stability was down and I rolled of the edge of the tyre to often.
This made it move around on power outta corners. I went back to a 190 and have had no problems since. Give it a go and judge for yourself, you might like it.
Kawasaki Z1000r 2012
- jess21
- State: Overseas
im afraid to turn 180....
I always fitted 180s to my '03 z1000. Better handling, and zero problems
csgup1
I put 180/55's on an 04 zx10 and they felt good. easier tip in and good stability in corners. If the rubbber is really sticky then you can give it a fair bit coming out too.
i ran a 180/55 on the back of my z1000 when i had, it i rode right off the edge of the tyre same as Jetpilot mentions.
not cool.
if you dont scrape pegs everywhere you wont have any dramas
not cool.
Wattie wrote:i ran a 180/55 on the back of my z1000 when i had, it i rode right off the edge of the tyre same as Jetpilot mentions.
not cool.
I did the same on the Crim, decided to stick with a 190 after that.
- zx899r
sameo on mine 9 but as i commute i was chewing out the centre, problem solved going to a 180,better tip in you notice the differance.JetPilot wrote:I did this on my ZX9, Yes it turned in better but straight line stability was down and I rolled of the edge of the tyre to often.
GO GREEN!
go a 190/55...best of both worlds
i'm now running a 190/55 michelin race... works a treat, and the price was right...(thats why i bought it)
addicted to corners
