signed
Don't let the smoke out of the box!
Yeah I get that bit well and truly thanks mate. It's just the smoke in the boxes I struggle with. Motors, carbs, gearboxes, suspension and brakes are all quite acceptable to my mental processor, but throw in electricity and it overloads and shuts down on me??????Stereo wrote:Sticking in a jet kit wont affect performance... the idea behind a jet kit is to give you adjustable needles... which allows you to make the mixture richer or drier... so by default if you set them up as "factory" it wont affect it at all... However, dynajet have a chart somewhere with their "recommended" settings which should offer some improvement with a standard exhaust.
You cant just swap leads.... the cylinders are all timed.... so it fires for example cylinder 1, 3, 2, 4.... etc.... if you swap the leads the engine wont run because the cylinders are firing in the wrong order.... I think it would also fuck your engine if do it for too long, but dont quote me on that, I tried to get mine running for a full 5 mins before I realised they were in the wrong order and the engine was fineStrika wrote: Is it possible to swap the coils from one side to the other or are they unique? Surely you can just unplug em and replug them into the other HT leads????? Or am I being simplistic???
Thats a question for the ZRX owners clubMick C wrote:Do the ZRX's have coil-overs or two coils doing two plugs each?
Mate, maybe I have come across more of an idiot than I intended. I realise each lead must go to the correct cylinder. But I was sure this was routed from the CDI through the coils. So was asking if the coils could be swapped to the other side to eliminate the coil being the issue before a carb strip. ie provided I connect the correct wires from the CDI to the coil. I realise if I just swapped em without changing the CDI Wires it wouldn't run. But are the coils unique to each side was what I was more asking??? It's just that getting the Carbs on and off a Rex is not the nicest job ya wanna do, unless you do it 30 times a day and are well practiced. Otherwise it's along, slow, fiddly process and often frustrating process. There isn't a lot of room down there. Draining the float bowls was frustrating enough!!! So I am just trying to eliminate issues as I go and the coils sit right under the tank and are easily accessible. As are the CDI wires and the plug leads..relatively. So was thinking that if I swap over the coils and the prob changes to another cylinder, then I have my answer. While I will check the HT leads, it is a rare thing that they would go on an 8 year old 40k bike. But As I said, I will check them at some point to eliminate that as a cause.Stereo wrote:You cant just swap leads.... the cylinders are all timed.... so it fires for example cylinder 1, 3, 2, 4.... etc.... if you swap the leads the engine wont run because the cylinders are firing in the wrong order.... I think it would also fuck your engine if do it for too long, but dont quote me on that, I tried to get mine running for a full 5 mins before I realised they were in the wrong order and the engine was fineStrika wrote: Is it possible to swap the coils from one side to the other or are they unique? Surely you can just unplug em and replug them into the other HT leads????? Or am I being simplistic???
Mick C wrote:I have to agree, if you want to make sure whether it's to do with the electrickery or not, the easiest would be to check for spark and confirm whether the plug is wet. You could also try swapping around the coils to see if the problem moves with it.
Still kind of sounds like a carb problem to me though, but then my point of reference is dicking around with 33-year-old Mikuni round slides, so I don't know that I can help too much
Well it's not the coil then otherwise it would take both of the plugs out.Strika wrote:...To answer your ? MickC, the rex has two seperate coils, not individual coils for each cylinder like later stuff.
