Tank Foam - Its great stuff..
This is for Joe.. :-)
ANTI-SLOSH FOAM BAFFLING
FuelCel Foam is a special open-cell sponge-like material which only reduces the tanks volume by 3-4 percent. When used with our Kevlar fuel tanks, FuelCel Foam helps suppress explosion, absorb some impact energy and most importantly, CONTROL FUEL SLOSHING.
Fuel sloshing in a motorcycle is a significant factor in upsetting the center of gravity due to the violent positive and negative accelerations that are imposed during racing. This sloshing acts like a heavy uncontrolled weight that has to be compensated by your suspension system, something like a liquid monkey constantly playing havoc with your handling. With a half tank of fuel, (common for most sprint races assume 3 gallons), that's 18.6 pounds slamming into the front of the tank when brakes are applied. Then slamming to the side after you have established your lean angle in the corners. Then slamming to the back of the tank when you hit the gas. But due to physics, that 18.6lb can act more like 60lb for that initial moment the fuel sloshes to a stop at the ends of the tank!
Riders report that installing FuelCel Foam gives the impression that they had their suspension done, even to the point of having to adjust their riding style because they were always making minor adjustments compensating for this fuel slosh. FuelCel Foam will enable you to ride more precise lines on the track thereby decreasing lap times. A very small investment to maximizethe potential of your new FuelCel.
Re: Tank Foam - Its great stuff..
Wait a minute, so there's a 27kg liquid monkey in my tank? And tank foam stops him from getting out and playing with my suspension?
Spot on Mick :lol: ............................Group Buy?
Bogan
Post by Bogan »
Stuff that, I wanna see the liquid monkey... Can we get two bikes together in the same place for liquid monkey porn?
Tony
I have become race...
6maniac
Post by 6maniac »
While we're at it, can we get some swing - arm foam ( as used and recommended by our illustrious leader ) !! and a side order of Yak Fat !
And did someone mention monkeys ??????? :twisted:
will that get me a 39?? :lol:
I like the idea of the liquid Monkey changing my suspension. 8) Sort of takes you back to the 70's.....
Sharky
Post by Sharky »
Ok sounds great in theory....
Are you saying we could get a large enough piece of foam through the filler neck of a standard jap tank to make a difference ??(yes I know foam squashes down... :?
It's gotta be better than the shit from Clark Rubber! :lol:
I just don't fancy opening the tank to squeeze the fuel out of the foam for those last few laps...
I hear it makes the bike flip at high lean angles!!!! there is even video proof
http://www.vimeo.com/2627898
jonoZRX
Post by jonoZRX »
Mick C wrote:Wait a minute, so there's a 27kg liquid monkey in my tank? And tank foam stops him from getting out and playing with my suspension?
He's not as bad as the 90kg monkey on the seat :lol: :lol: :lol:
6maniac
Post by 6maniac »
Thats two monkey mentions. :twisted:
Lone Wolf
Post by Lone Wolf »
I just saw a liquid Monkey run past my window............wait............maybe I'll just have another drink
6maniac
Post by 6maniac »
That's it....... :twisted:
