Graphic for Polos wanted..!!!
We are adding Mornington Kawasaki to the polos and it would be good to get em on the sleeve.
It will replace the KSRC-AU, which was only put on to even the shirt out.
We need something vertical in the ratio of 100mm high x 25mm wide..
There web site is here to see what there logo currently is.
http://www.morningtonmotorcycles.com.au/index.php
MrWasabi
Re: Graphic for Polos wanted..!!!
Post by MrWasabi »
ive looked through all my fonts and i dont have anything that matches their logo. anyone know what type of font that is?
queue Rob...
Mistakes:
I was going to ask the very same thing! :roll:
Something similar would be ok....
How's this?
P4nza
Post by P4nza »
I recommend adding Tinman's Avatar :kuda:
Dave Problem here is our limitation on size & their name being long, this will also be a 1 colour print (white) on a black background, as per previous polos.
Yep, something like that would be ok.
Although we just need it in white text on black background..
What do ya think Rob.?
We could work with that concept..... give me a sec...
Could work Dave?
I like it....
Lock it in Rob.. :-)
(with correct Aitkens addy.. :-) )
I will have a play with typefaces & send you a final proof for both sleeves ;)
MrWasabi
Post by MrWasabi »
best i can do in 30 minutes. gotta go to work. cyas.
Mistakes:
I emailed my crap over Rob... 8)
OK Dave, hows this for Final artwork? All other prints to stay the same as the first run ;)
Locked
