'04 zx10 cam timing?
- Aussie Ninja
I am thinking about getting my intake cam advanced 3 degrees. Apparently it fattens up the torque curve without hurting the top end. Anyone heard about this? Anyone done this? Will it do as advertised?
1998 ZX6R R.I.P.
2004 ZX10R killed by Roo.
2011 ZX10R
1998 ZX6R R.I.P.
2011 ZX10R
Dr Phill
Re: '04 zx10 cam timing?
really? let me know how it goes mate.. will be intruiged somewhat as to how it affects it
The Doctor
2004 ZX10R/RR
Akropovic Race S/S-Carbon Full System
PCIII
K&N Filter
GPR Damper
520 Chain Conversion (-1F+3R)
8000k HID system
Colour Matched Painted Wheels w/ Polished Outters
Kawasaki Solo Seat Cowl
Tinted D/B Screen
Adjustable Rearsets
2004 ZX10R/RR
PCIII
K&N Filter
GPR Damper
8000k HID system
Tinted D/B Screen
Adjustable Rearsets
Advancing the intake cam up to 5deg over stock is something that has been happening on bikes for years.....when the Katana was first introduced to NZ back in the early 80's, the first model was a 1000cc, not 1100cc.......the standard inlet cam on the 1 litre Kat had cam-tining that was advanced 5deg over the 'stock' GSX1100 cams used in normal gixxers....these cams used bolt-up cam sprockets, not slotted sprockets (which allow inlimited adjustment over a certain range..)
3deg advance of your inlet cams is unlikely to really make any difference on the road, but could be worth trying on a race bike or track day only bike ? You should call Rick Miller at RAM Engineering, or even Peter Pulford out at Mitchell, and put this to them. Peter is a hog specialist, but knows his way around motors better than most others here in Anarchy Road.
