GPX250 water pump gasket!!
- gpxpunk
- Bike: Don't have one
It seems that since I have a 1987 gpx250, the water pump requires a gasket. Anything after that has an O ring instead!! problem is they dont make the gaskets anymore ihave been told from kawaskai, Is there any way of getting a gasket coz i tried the o ring and it kind of doesnt work.... I have heard you can get kits were you can make your own, but are they anygood coz i think these are mostle for cars instead of bikes. i tried gasket goo but thats crap....
1987 GPX250R. memories
2002 ZX7R . sold!!!!
- Cwidova
Re: GPX250 water pump gasket!!
at work i buy gasket paper and make gaskets for engines that would do more work in worse conditions and have never had a problem with it at all!!! there are a few differant type of materials you can buy so make sure you choose the right one and make sure its as close to the same shape to the original as possible so you dont block any holes and stuff that shouldn be blocked up..
'06 ZX6R
'10 FE390
'10 FE390
- gpxpunk
yeah the old gasket was destroyed, so aslong as i can find some descent gasket material i should be ok... i hope.
Always happens just b4 a sunday run but atleast i have a couple of days to fix this time.
- Cwidova
you should be able to just cut out the mating face shape of the pump itself and be alright......murphy's law always happens like that!!!
'06 ZX6R
'10 FE390
'10 FE390
- gpxpunk
yeah thats what i was going to do, but i know there is some pretty shit gaskets kits out there, so i was wondering if there is a good brand i should be looking for!!Cwidova wrote:you should be able to just cut out the mating face shape of the pump itself and be alright......murphy's law always happens like that!!!
Always a problem when the bike is 22 yeards old
- Cwidova
basically you get what you pay for.....have a look at them see if they look good and feel them too make sure they aren't crumbly and bend them.....ones that have been sitting there for ages go brittle and lose their flex and just end up snapping
'06 ZX6R
'10 FE390
'10 FE390
- gpxpunk
do you need to go to a bike shop or could they be bought from any auto shop?
- Cwidova
we buy ours for a bearing and industial supplier....but i would say that somewhere like repco, bursons or supercheap would have it too
'06 ZX6R
'10 FE390
'10 FE390
- gpxpunk
all good just rang my nephew who works at autobarn, he has 3mil, 2mil & some other stuff, i even get home delivery haha what service !!!
Thanks for the comments guys.
- gpxpunk
just got the gasket paper.. went for the 2mm, looks strong, and nowhere near brittle in anyway. So i know what ill be doing tomorrow, while im coughing and sneezing through my flu...lol
- gpxpunk
ok made the gasket, took a couple of hours to get it right,
put it on and it was still leaking!!!
realised it was the washes coming off the pipers so went back down to kelens and got them both,
tried to take the hoses off and realised the old owners had lost the bolts that contect the whole pump on and the whole thing come off, oil went everywhere.
So all in all between coughing and sneezing i have got the bloody thing back together for now, but will have to fix a far bit soon which im not happy with.
- mike-s
at least it looks like it's sorted though, that's a big plus.
- gpxpunk
hopefully nothing goes wrong!!! ill see tomorrow on the ridemike-s wrote:at least it looks like it's sorted though, that's a big plus.
update!!!! well seems i have snapped the housing and cooliant has been leaking then flowing everywhere today, lucky the ride ended in penrith where it was only a 5min ride home!!
- gpxpunk
ok update, picked up the waterpump housing coZ the other one was cracked, found out the pump was never bolted in so bolted it in, and got it all fitted{new one off a zzr250 engine with oring not gasket thank god} filled the coolant {no leaks yay} turned her over and started to warm her up and looked under and again coolant, this time it is coming from where the pump fits onto the engine, SSSOOOOOO now ill go pick up a bloody pump{ i should have just go the whole unit} so hopefully tomorrow fixed.
Had to drive to work today in the 4 wheel cofin...... now again tomorrow not happy!!!!!!
- Sulli
FIPG (Form In Place Gasket ) The stuff available is use specific eg water pump. oil based, acid based. etc see your local automotive parts retailer
