which exhaust for 06 zx6
- Wardy
Thinking about keeping the 6, but don't want to keep it standard, so will start with the exhaust first.
What have people used that looks good?
Sound is not really an issue, and I don't really need any more power from it as it will be mainly a road bike.
What do people think about the one from hotbodies? Attached.
Also which is the best double bubble screen?
- hotbodies exhaust.JPG (19.88 KiB) Viewed 5086 times
06' zx6r limited edition
- aus636
Re: which exhaust for 06 zx6
I have heard from the US forum that a lot of heat is generated. Depending on how much you want to spend I would go Micron Ultra lite Titainium with the full serpent system. I think complete for this bike about $900 US & $100 delivery check this sight out
http://store.micronexhaust.com/index.ph ... year=05%2B
Then you need a pwer commander & custom map $600
- ZX6R micron.JPG (141.01 KiB) Viewed 5056 times
Did you know Micron went bust
there are suppliers with stock but limited.
Got the same pipe for my tracky
- 11022009430.jpg (117.68 KiB) Viewed 5049 times
Russ the best looking pipe would have to be Caths 2 Bros & ya cant beat the sound
The singles pipes look strange with the plate holder that comes with them.
& here is a an Eye Candy link from a previous post .... Thanks to Red_Dave:
http://www.ninja6zone.com/forums/showthread.php?t=2529
- Wardy
Thanks guys.
Looks like I'll have to rob a bank. Forgot how expensive things are! The two brothers pipe does look the goods.
I was looking at getting a Jardine but ended up getting an Akrapovic slipon. I need a clean fender eliminator.
But damn this side mount looks horn!
- Cath
Nothing beats the Two Brothers for looks, IMO (though the Laser comes close).
(but the Micron apparently has an extra 3 hpw in it
I really like the underseat exhaust - and an added bonus is it's much more protected in a small off
My screen is an Ermax double bubble. I like the look of it, but I can't recommend it. On hot days, the plastic instrument surrounds can actually melt from the focusing of the suns rays. Maybe they've fixed the problem, maybe they haven't - I have no idea.
aaarrrr the nicest rear end in town
- Wardy
Looks good Cath, have you put in a pcIII and had it tuned or just whacked it on? Also where did you get yours from? Did all the screen bolts line up? I've heard there is issues with some screens, can't remember which ones though.
- Cath
No PC3 - I could barely afford the slip-on at the time! I got it from starcycles.com - When I got mine, there was nobody importing them to Australia, but several companies do now.
No problems fitting the screen.
check out D&D, i love their twin can exhaust
- Wardy
I have ended up with a yoshi. picked it up cheap at the Mladin sale a couple of weeks back. It is sitting on the bike now but I need to get an exhaust bracket, the kit was missing it.
I've ordered a pc3, gpr damper, crg levers, speedohealer, integrated tail lights, k&n filter, double bubble screen and rear cowl. Should all be here in another couple of weeks.
I will install a preset pc3 map and get it onto the dyno as soon as I get a chance. Any recommendations for dyno tuning would be helpful. Also when doing the KLEEN mod would you recommend connecting the crankcase vent tube to the pair valves or leave it connected to the airbox.
Russ
Russ
