Pre-load adjuster's.....
Team Monster
Post by Disco »
Was just wondering if the part in the Pic below can be replaced without the whole fork being replaced? :oops:
Eg. If it had a big scrape on it (adjustment part).Also would it be a lot of money to replace?
Dave.....
Re: Pre-load adjuster's.....
what have you dun dave ???? :shock:
Rossi
Post by Rossi »
timmyrocks
Post by timmyrocks »
is it only the nut of has the flat head screw driver adjustment been damaged?
if its the nut you can get preload adjusteds and fit them so you dont actully use that nut, they sit ontop of and you can adjust by hand so you dont have to worry about a spanner slipping if its slightly damaged.
if it gone and you need a whole new fork top, that may be a little bit more expensive but im shore a wrecker somewhere will have damaged legs and will want to get rid of them ;) try findapart maby
Team Crash "09"
WR125 2004 Husqvarna :P
smithy5
Post by smithy5 »
hoffy wrote:what have you dun dave ???? :shock:
+ 1... What have you done...... :? Too many hints and snippets lately :? ........... That looks like a brand new bar etc in that photo..... :? :?
