My 96 ZX6 has been parked up for a while now, and i decided to get her going again last night after a bit of cosmetic work was completed. Now the fuel pump has failed.
Prior to this I had drained the tank and carbies back in Febuary as I knew it would be a while and didn't want the fuel going stale in the tank. Why did i do this you ask, well last time i parked the bike for a while, the pump sh@t itself, and I had left it with fuel in it, so this time i figured I'd drain it.
I was lucky last tie and had a spare pump, but this time, I don't have a spare, and I'm not even entertaining the thought of getting a price of Kawasaki, I'm sick of calling them thieves.
What i'm thinking is an aftermarket universal pump. I know it only needs to run between 11-16 kpa, I just need to find a reliable one.
Does anyone have any suggestions of universal pump brand, or a way of resurrecting my old pump.
Farked Fuel Pump
- Poyda
Farked Fuel Pump
Pete
The (no longer) ugly 96 ZX6R
- z900/zx9
Re: Farked Fuel Pump
I have had an aftermarket fuel pump on my zx9 for the last 20,000 ks.It came from bursons i will have a look to see if i still have the part number
- drunkmeerkat
Poyda..
You sorted this out yet ??
I have a working factory spare in the garage if you're interested....
cheers.
cheers.
Kwak addict
- Bike: ZXR750
Fuel pumps are a standard Kawasaki problem, the contacts corrode & fuse together. It's a simple fix, just take the black cap off the end, flick the contacts apart (they fuse together very lightly) & dress the contact surfaces with a piece of 600 - 800 grit sandpaper folded in half - or use your missus' emery board/stick/thing that she uses for her fingernails.
Give the contact surfaces a wipe to make sure there is no residue leftover & you're good to go.
Ex T.K.A. ZXR 750 RR
ZXR 7/9 L3 Streetfighter
- Poyda
Yeah got it sorted. I'd keep a tight grip on that if I were you.drunkmeerkat wrote:Poyda..
cheers.
Did that....stupid thing it is too, but alas was not the problem. Seems the insides have seized up but soaking in carby clean is fixing it.Kwak addict wrote:Fuel pumps are a standard Kawasaki problem, the contacts corrode & fuse together. It's a simple fix, just take the black cap off the end, flick the contacts apart (they fuse together very lightly) & dress the contact surfaces with a piece of 600 - 800 grit sandpaper folded in half - or use your missus' emery board/stick/thing that she uses for her fingernails.
I've got an after market arrangement happening now, thanks guys
Pete
