Tyre Pressure.ZXR750
				Gav
 - Bike: Don't have one
I run 36psi in front,41 in the rear ....is this right ?. and what about in the warmer months.does this change?.
  I run Pirrelli Diablo's
				oldmate
 - Bike: ZXR750
Re: Tyre Pressure.ZXR750
That's what i rum on my zxr and I've never had a problem the only thing is I'm running Michelin tyres
For normal road riding stick with those pressures, at least you should get good tyre wear.
				Gav
Thy were a little low.About 30 front and same rear.and did notice some tyre wear..robracer wrote:For normal road riding stick with those pressures, at least you should get good tyre wear.
30 front and read is good if you want loads of grip
