zx2r gear box
				ashman_333
zx2r gear box
hay has any body had there gear box serviced mine is starting to slip in to nutral when going from 1st to second just wondering is it easy or is it easyer to just bolt another motor in one with less K's on it pehaps
				craig
Re: zx2r gear box
are you just missing it ??.............check your oil too.... would not think you'd need to toss your motor out ...but if your in melb give me yell i'll have it
						- dave#3
 - Team Ninja
Re: zx2r gear box
Mate, I'd start with an oil change using semi-synthetic oil (Motul 5100 is good) and adjust and lube your chain.
Other simple things to check include the adjustment (positioning) of the shift lever, make sure the shift lever is appropriately lubed and correctly tightened.
How many km's on the engine and 'box? Oh, and if you end up ditching the motor look up Slow and Wobbly and offer him a belated birthday present
dave#3 |  '03 z1000 roadie |  '08 zx6r tracky | '03 KLX400R dirty
http://www.oz4x4.net/gallery2
- kevindinho
Re: zx2r gear box
This happened to me a couple of weeks ago, mine kept getting neutrals. Good ole Tim taught me a technique where you shift and release the clutch after its in gear, Nice and smoothly!!! now i hardly ever get these phantom neutrals unless i shift extremely fast. Hope this helps.
