Hi
Can anybody tell me if the Australian Model ZXR 750 92 model has any power restrictions i have read that the English model was limited to 100hp.
If this is the case where are the restrictions and how can they be removed
Thanks
ZXR 750 restrictions
- MadKaw
- Administrator
Re: ZXR 750 restrictions
Yep, its the same, 100 hp limited... and there not cheap or easy to remove.
Unlike carb or intake restrictors the ones on this model are not easy to remove as I believe the cams or pistons need to be changed..?
Theres a great article here
http://homepage.ntlworld.com/webzxr/zxr ... ormer.html
- greenman43
Cams for bigger lift and duration, pistons for higher compression, and igniter for (most likely) ignition curve and rev limit.
Brian
Brian
