License saver
Rossi
License saver
Post by Rossi »
This has got to be one of the best ideas to come out in the UK yet.
the magical flip-tip no plate
folds up at the touch of a button
Click on pic for larger image
solonoid controled for trouble free operation
for track use only.
Folds in half in less than a second
mfzx6r
re: License saver
Post by mfzx6r »
Rossi
I think I've seen that before
How $$ is it ?
mario
Mario
'01 zx6r
klx300r
Part of the "Fookarwe" tribe
Rossi
re: License saver
Post by Rossi »
Mario
it retails in the UK for 70 pounds approx Au$168
Cheaper than my last fine :lol:
re: License saver
Has anyone seen the spray that you put on your plates?? Apparently makes them invisible to cameras.
I hear hair-spray does the same thing, but I don't personally believe that!
http://www.ghostplates.com/
This site has Australian ordering details. Be prepared to be scared at the price of a can of spray tho!
Rossi
re: License saver
Post by Rossi »
yeh
I am impressed with the lens type plates cos I can understand how they work and have also seen a few in the flesh too but the spray I think will only work if the speed camera has a flash unit......only ones I've seen so far don't flash or else I managed to brake hard enough to get below the trip speed :lol:
Re: re: License saver
aardvark wrote:Has anyone seen the spray that you put on your plates?? Apparently makes them invisible to cameras.
You can only get the best dodgy illegal shit from the coppers
re: License saver
Or, alternativley....
The ideal angle for bending your plate so that the cameras can't take pics of the last digit is 30 degrees.
:wink:
aardvark wrote:Or, alternativley....
:wink:
Bluefly
Patient 46
Patient 46
Post by Bluefly »
:wink:
Jas you've just restored my faith in the possibility of there really being decent cops around! notworthy.gif
Hayden who??
mfzx6r
Post by mfzx6r »
:wink:
UP or Down ??
mario
Mario
'01 zx6r
klx300r
re: License saver
Maybe it's one of those mysteries...
"You must bend the number plate Grasshopper, to an angle of 30 degrees"
"But which way master, which way?"
"You must seek the answer within Grasshopper, for I cannot tell you. If you are correct then all roads will be open before you, but if you are wrong then beware..."
cue mystical music
Blackzxr
re: License saver
Post by Blackzxr »
My rego label is mounted to the side of my plate. I can push it up so it blocks the plate from the side. I have been done for it once, think it cost me $120 for an obscured number plate, but no points. The copper checked it after i used the "it blew up bit", bullshit he said feel how tight it is. I have loosened off the tension now so it pushes down easier.
Think it was Mario's mate who got done in Tassie, for putting a leaf over part of his plate. That one didn't cut it either. I can imagine they have seen it all.
I know another guy who has hooked up a motorised track thingy (yes that's the techo term) and his plate rolls up under his seat.
Rob
Black 03 ZX6R
BA XR6T
re: License saver
Come on you guys... do I have to tell you everything?
Looking at the back of the bike, bend the right hand side of the plate towards the front of the bike...
If you looked down on the bike, the plate would look like this.
___/
Got it? Those greed cameras then cannot take pics of the last digit of your plate. And if you only do it on one side, it doesn't look so obvious from behind. Still, you need to be careful of cameras mounted on the median strip. It's only cameras parked on the proper side of the road you'll fool.
And remember, there is a time and a place for everything!! Ride safe.
re: License saver
Spoken like a true copper...........
Thank-you master....
ninjaboy
re: License saver
Post by ninjaboy »
When in Japan a few yers ago (ok, back in...1999), they had a whole shop dedicated to this sort of stuff: A similar gizmo, but a sliding roller shutter type cover would slide down within 0.5 seconds to cover the plates. Another was a signaling police radar detector with a light source - just a small unit, too! Like the ones for cars buyt about the size of a matchbox. The reflective paints they had were REALLY good - reflected to the naked eye also, so the plate was virtually completely obscured, but during the day it was clear as crystal.
There were heaps of other stuff too, but dont remember most of them.
NinjaBoy
At least my mum thinks I'm cool...
~Sweet~!
'98 ZX-9R, Royal blue!
