How to - make a good thread go bad.!!!..
- MadKaw
- Administrator
This has been around for a while but its good read..
How to Lap Eastern Creek
By - Josh Brookes
TURN ONE: When screaming down the front straight in top gear (sixth), keep to the far right of the track. Flash past the braking marker (which one depends on the bike you are riding), shift down one gear (fifth) and peel in (careful not to square the corner, your knee is hitting the deck mid straight). Open the throttle slightly as soon as you can - this keeps the weight off the front wheel and the bike stable. Pull the bike into the apex (it's bumpy because of the water run-off there) and hold it on the apex for a long time - more than most other corners. When you can see your exit, accelerate hard to the outside of the track to be ready for...
TURN TWO: It's a double apex corner, so brake hard, shift down three gears (second) and take the first apex early, right on the ripple strip (dipping by the third blue strip). Let the bike run wide mid-corner (but still ripple side of the crack in the tarmac), then pull it back to clip the second apex on the exit. Hold it tight (on the paint) to avoid the off camber section. The wrong set up here can cost you a second. As you exit, driving hard, short shift to third and the same time as you change direction and body weight (watch the wheelie! fine line here between perfect set up and the high side) to enter...
TURN THREE: It's a late apex here, after the ripple strip, so watch you don't catch your knee in the grass. Drive the bike to the outside of the track again, then upshift to fourth. Pull the front wheel up over the bump on the crest heading to Turn Four to keep the bike stable. As soon as the front wheel chirps back to earth, nail the brakes and downshift one (third) for entry into....
TURN FOUR: Tip in, then crack the throttle open before you get to the exit. Again this keeps the weight off the front wheel, which can cause the front end to fold. Hold it tight (keeping it on the ripple strip), then drive hard to the outside of the track, then turn hard to the apex of...
TURN FIVE: It's crucial to keep the speed up here as the exit is uphill. Maintain as much corner speed as possible. I use all the track to drive up and over the hill, being careful not to induce to much wheelspin. Snick fourth gear and shift to the right side of the bike, on the way to....
TURN SIX/SEVEN: If its dry, brake hard using the concrete strip on the right. If it's wet, don't go near it - it's too slippery! Downshift one gear (second), then shift your weight to the left-hand side as you crank the bike on to your knee. Apex the ripple strip late. Again, keep your momentum high for the uphill exit. For me, it's often wheelspinning and wheelying as I snatch another gear, ready for....
TURN EIGHT: The crest on Turn Eight's entry is bumpy and the track drops away fiercely, so the bike can be shaking all over the shop. Wait until the bike settles down, only for an instant, then lay it on it's ear. I like to apex early so I can drive out hard to the far side of the track (watch the bump on the exit!) and set up for....
TURN NINE: Pull the bike back to the middle of the track, instead of far left, to enter Turn Nine - I think it's faster than using all the track. Shift down a cog (second). Hold it tight all the way around the ripple strip, then drive out to the concrete ripple strip on the exit. If I'm really trying, I often hit the dirt. Try to avoid that.
TURNS 10/11: I shift up twice on the run to Turn 10 (fourth), then tip in late downshifting once (third), before I do so. Once I'm cranked over on the ripple strip, I downshift again (second - I hardly brake here, as I'm right on my side, but do this wrong, and you low side), then flick it over the ripple strip of Turn 11. Try to make one turn out of Turn 11 and...
TURN 12: Let it drift out to the edge of the track from Turn 11, driving hard, then pull it back in for as late an apex as you can. Every kilometer an hour you can make here means a few extra down the end of the straight, so it's a crucial corner. The bumps on the exit can set up a weave, depending on your bike. Tuck in everything for the run down the straight - toes in, elbows in, head down - on your way to top gear, and Turn One, to do it all again!
first published by AMCN March 12 04, with edits included from personal conversations and Circuit Breakers Race schools....
BTW - This was on a 600...
By - Josh Brookes
- Tinman
Re: How to Lap the Creek..
Nice might have to try this when I get out to the creek with the 600
Live 2 Ride!
Honda 2003 Race bike
2009 Mozzie Green ofcourse
http://www.rcutopia.com.au
Been a while Tinny
- tim
Good insight, and sounds like a lot of work to me
Lap the creek?
Lap the creek?
One day Tim we will drag your sorry arse down to the creek for a floggin
& you will enjoy it
promise!
- fireyrob
Cheers for the reminder madkaw! Must study this b4 the next trackday, print it out and read it between sessions till it sinks in! Seems as though the SBS lines are completely different so start again!
- Tinman
Yeah but I think I'm up for the challengerobracer wrote:Been a while Tinny
Live 2 Ride!
just lean the carn't ... and then rev the carn't ...
done
done
- Glen
Very handy. On the 600 I know what he means about going up the hill to turn 6/7
yeah. im going to ring up this Josh Bloke.
he's got no idea...
Not once does it mention "just lean the farker", "big black darkies" or "Just stick it in"
NOT HAPPY!
he's got no idea...
NOT HAPPY!
- Poyda
I can read this over and over, until it is imprinted on the inside of my eyelids, but i still can't get T2 right. Too slow, too fast, too wide, too tight, inside the crack, outside the crack. I'm all over the place like a mad womans s@#t!!!! Even a CB Race school didn't fix it. Everywhere else, I can have good lines, smooth & fast, but it's just this one farker of a corner
i think i've seen to many people lay it down there and am waiting for it to happen to me. Might need to leave the skirt at home next time i go out, man up and either throw it away or get it right.
Pete
The (no longer) ugly 96 ZX6R
Fastest way round hoff... get off the bike
- off camber.jpg (49.59 KiB) Viewed 3551 times
- Greenblood
Can I come to Rob's school of hanging off?!!
2017 ZX10RR Road
2006 ZX6R Race Bike
1997 ZX7R Pirate MkII
2006 ZX6R Race Bike
- SoundGuy
Poser!robracer wrote:Fastest way round hoff... get off the bike
http://www.myspace.com/9planetsmusic" target="_blank
