Hi All,
I have a nice green tank for fluffy, problem is its been sitting around for ages (12months+) with a bit of old fuel in it.
I can pull the tap of and clean but the manual states to "wash" the tank internally with a high flash point solvent. Not sure what to use or where to get it, any ideas?
Matt
cleaning a fuel tank
- timmyrocks
Re: cleaning a fuel tank
i use some kero or metho and give it a good swish around in there, both will be fine if a bits left over and get mixed in with the fuel
supercheap will help u
Team Crash "09"
WR125 2004 Husqvarna
Team Crash "09"
avgas?
Brake fluid works well at removing any excess rust. It needs to sit for a couple of days, however. Very hard on paint and fuel pumps so be carefull.
- matchan
I'll give kero a bash, cheers Tim.
Matt
Matt
Oh & Matt when you are done leave her in the sun...... in this heat any left over liquid's should evaporate pretty quick
- matchan
thanks for the tip Rob!
