 A couple of valves were tight but I spent all day setting all the valves to the wide side of the specs- digital verniers help- amazing how much shims vary from the sizes printed on them. Mech guru was telling me some extra power is available setting them wide through increased compression coz valves are closed longer- valves run cooler too. I always set them wide previously anyway coz they generally tighten over time and I'd rather have some extra time up my sleeve between valve adjustments. Pretty easy on ZRX anyway. Not like GT with it's shim under bucket setup....
Found a couple of other problems though and one is of great concern, the other minor- three sparkplugs were oiled up heavily as I changed them- the valve cover wasn't screwed down very tight and I assume that the four sparkplug gaskets weren't pulled down enough. They are in new condition. The other issue I discovered was of the four engine cradle bolts on the right hand side of the bike, one was missing (!) and one looser than finger tight (!!!!!!!!!) - both on the top side behind the radiator shroud. I had a problem of tankslappers at high speed with the bike some time ago- and ended up putting in new steering head bearings (they were buggered) and wheelbearings as well as front tyre trying to get rid of speed wobble. It has largely gone, but still has a bit of a weave- maybe having tight engine cradle bolts and all of them there might help! I have taken one of the lower cradle bolts out and put it in up top so I can reassemble the bike and easily instal a new one next week when I can buy one. I have torqued them to specs and loctited them too. Kinda shits me how crap the build quality is on this bike. All sorts of shit has fallen off, cracked or rubbed against things it shouldn't have. I was thinking today there is no bike at any price that I would prefer than the ZRX, so she's staying. Will just have to persevere to keep it from falling apart.
 Yeah I like Kawasakis.
