anyone have any hints?
where to buy? hex bits for ratchet...
- Six Addict
- Pinchy
- Bike: Ducati
Im trying to find somewhere to buy hex bits for a ratchet. REPCO sell nothing bigger than 12mm (i need big ones to do my front axle) supercheap may have some, although its hard to tell from the catalogues...
- bishboy
Re: where to buy? hex bits for ratchet...
Can't remember where I got mine from
, would have been either Super Cheap or a tool place such as Glenfords or Trade Tools Direct
84 KX250
79 KX/KLX 250 evo project
YZ465 latest project
Spot on....... Owen find a tool place for those or get em off ebay.Cwidova wrote:total tools has those sorta sockets
Sidchrome do a set for 1/2 inch drive or if you can track down your local snapon dealer you can buy single 1/2 inch units like in the Pic
- pics.jpg (242.62 KiB) Viewed 3674 times
total tool, or an actual hardware/ enginneering supplies place?
Boltmaster ?
snap on is good shit, but you wont affort much with a under 25 year olds budget..
Boltmaster ?
- Six Addict
- Pinchy
- Bike: Ducati
yeah so i see... only really need two at this stage... might try and get to total tool sometime...
- Glen
I have an assortment built up after years of owning Kawasaki's where they change the diameter of the hex head every bloody model.
I got mine from Total Tools but last time I was in MCAS I noticed they have a multi fitting one for about $20. Maybe have a look as you'll at least have it for a couple of different models.
- triway
I just found a bolt with the head the correct size that I need and welded an old socket onto it!
www.techspec-aus.com.au
www.trackdaypro.com.au
- Frank
I tried to get one for the front axle of he zx9 from total tools in Castle HIll, they didn't keep them in stock that big and wanted $68+GST ONE hex and that was for some brand that I never heard of before, get one of the multi tool ones of off ebay for about $30 it's like 4 in 1 and then you just use a socket that matches the other side to the one your using.
GO THE BLUES
Life time member of PETA:-
Member of SRT
1998 Kawasaki ZX9R Track Bike
2014 Nissan Navara
Member of SRT
2014 Nissan Navara
- laidback
I got this on ebay...
You just use an ordinary socket on the end that doesn't go into the axle. I has 4 different sizes 17, 19, 22 & 24mm
- MrWasabi
- Team Kuda
pinchy, i got a thing like pictured above which doesnt fit my front axel, if you want you are welcome to borrow it for as long as you need.
- Blurr
Bunnings is your friend. A Kingchrome set that looks like Rob's ecept in a blue metal box will set you back about $40
Frank wrote:I tried to get one for the front axle of he zx9 from total tools in Castle HIll, they didn't keep them in stock that big and wanted $68+GST ONE hex.
- Glen
For 07 model ZX6's a Holden wheel nut is the correct diameter also, or the non business end of a sidchrome plug socket
- Six Addict
- Pinchy
- Bike: Ducati
thanks guys, i need 2, different diameters, i'll try bunnings, thanks russ
