Hi ,
The brake lever on my wife's bike has started to pulsate slightly when the brake is applied and I know this is normally caused by the disc warping but are there any other reasons for this to happen?
Thanks
Pulsating Brake Lever
- simpleton
KWAKAS SR650,GPZ900,ZX10,GTR1000,GPZIIOO,ZRX1100
OTHER Honda 250,Jawa 250,CX500,GSX1100,Yam1.1, Tri Daytona 900,Ducati ST2,Tri Sprint,Tri Tberbird, Breva 1100, Aprilia
THE MRS' KWAKAS GPZ250,Zephyr 550,ZR7,2010 Z750
OTHER Triumph TT600,Guzzi Breva 750
- MrWasabi
- Team Kuda
Re: Pulsating Brake Lever
as far as i know its due to warped disk(s)
Its the Disk for sure
get the wheel off the ground spin it & check the runout using a gauge or supported steel rule
- P4nza
- Bike: Don't have one
My gt550 had this problem... like rob said its the disks for sure... make sure u change the pads while ur at it
Team Crashed 2010
Team Crashed 2010
- simpleton
Rode the bike into see Jason Kain this afternoon, no signs of a warped disc, so he suggested I remove the pads and take any glazing off with emery paper. It appears to have done the trick.
oldman
Sanding the pads is good, also sanding the disks will help using 400 grit wet or dry sand paper.
Jim Beam also helps.
