Ive run out of adjustment on the gsxr600 front end. The preload is wound in fully and the compression is at full stiff. yet it feels underdamped everywhere and dives completely under brakes and bottoms out.
I know the best solution is a revalve and resprung but its too expensive atm. Im looking for temporary solutions.
Add more oil of the same oil to reduce the air gap?? how much more should i put in?? its 10Woil. and where can I buy a good measuring syringe ?
Change the oil? go heavier to a 15 w oil??
I am looking at changing the springs as well as I could probably do that myself without much issue. how much stiffer should i go and where can I get them from??
Im looking at changing the fork oil on the zx10 as well. Is it just as simple as turning the things upside down and draining the oil out and filling it up again with the same quatity that came out . And if i take them completely apart whats the best solvent to soak the tubes in to get the crap out??
Finally Ive got new cartridges for the zx10 and a new rear shock. Ive got a how to video that pretty much shows how to change the cartrides around but would love someone to give me a hand in melbourne. Theres a good bottle of scotch in it for ya
thanks and cheers!
