FI Light
FI Light
After installing the new pipe last night the FI light started blinking. I know it is from disconnecting the servo to the butterfly on the old exhaust. I couldn't remove the cable due to the strange screw head on the servo motor so cables are tied up. What is the solution to stop that damn thing blinking?
Re: FI Light
Most good aftermarket pipes have a replacement toggle to trick the system into thinking everything is good, without that you might have to put up with the light
unless you can make up the toggle / bracket........ you would only need a piece of alloy a drill & a bender or a good vice.
- Frank
Re: FI Light
What type of screw head is it? What does it look like? If you are in Sydney you welcome to come over one weekend as I have most of the security style screw heads.
GO THE BLUES
Life time member of PETA:-
Member of SRT
1998 Kawasaki ZX9R Track Bike
2014 Nissan Navara
Member of SRT
2014 Nissan Navara
- Blurr
Re: FI Light
it shouldnt blink as long as you still have the servo motor connected. You dont even need the cables connected to anything at this point.
Re: FI Light
I'm in Melbourne. I'm removing cables tonight. Light started blinking this morning.. servo still runs etc.. but from reading up it can go out of line which causes light. I have a service this weekend - perhaps they can fix
'09 ZX6R Monster energy
- Cath
Re: FI Light
My light stays on, no matter how much I adjust the block on the servo. Occasionally an adjustment will work and the light will stay off for 2 kms or so, then turn on and stay on again. I've given up trying to make the servo thingy work
Mine has never stayed blinking though - just on or off (though I guess blinking is just on or off too, but you know what I mean!
Re: FI Light
Maybe the blinking is a 09 thing.. I guess I could live with it.. 2 brothers comes out with a block that bolts onto the servo to trick it.. may have to go down that lane.
- Cath
Re: FI Light
That's the block that I have, Salty - from 2 Brothers. It worked for a while, then stopped working, and each time I adjusted it, it worked for less and less time.
But if it works for you - cool! I just wish it worked (permanently) for mine.
- Reedy
- Bike: Honda
Re: FI Light
Do what homer would do. duct tape over the blinking light. problem solved.
- Cwidova
Re: FI Light
there is a servo eliminator so that you can get rid of the servo and trick the bike into thinking there is one there....it's about $100 and i forget exactly what it was called....it's somewhere on this forrum we had the same discussion.
'06 ZX6R
'10 FE390
'10 FE390
Re: FI Light
Problem solved. One of the wires was jammed - so once the wires were removed from the servo the error went away. Apparently with the FI light illuminated the bikes leans up - so maybe a good idea to fix that Cath
- Cath
Re: FI Light
What do you mean by "the bikes leans up"? Sorry, but I don't understand what you're saying
Re: FI Light
The ECU gets confused about the fuel mixtures and will lean up the air/fuel ratio (letting more air into the mix) which can do bad things over time.. but then again.. maybe not???
- zxsixr03
Re: FI Light
Who told ya that? Its complete BS, no fuel management is effected with the FI light on from the servo anyway, if u have a error code or u actually get a fuel injection problem it might go into limp mode but still wise to fix it as you won't know either way if u do get a problem or if its just the servo keeping it on.Salty wrote: Apparently with the FI light illuminated the bikes leans up
