Gasket suppliers
- peterodactyl
- Bike: ZXR400
Gasket suppliers
I'm after a gasket kit for my zxr400 racebike and was wondering if anyone could point me in the direction of a supplier. I wouldn't mind a set of steel clutch plates either. I've tried Otobai and Victorian Motorcycle Wreckers, am going to give RB a call tomorrow. Is there anyone else apart from that?
Kawasaki don't want to have anything to do with getting bits for greys.
Thanks guys.
Thanks guys.
- mike-s
Re: Gasket suppliers
Regarding gaskets, if its for things like side or rocker covers then maybe just buy some gasket paper and trace it then cut it to suit. You can get various thicknesses from 0.5mm through to 3-4mm and in various materials like paper or cork to suit the oem's gasket specs.
tracing a gasket for a cam cover, with all the small bolt holes - is about as much fun as having one of those small umbrellas dragged down the inside of your JT after a footy trip to Surfers !!
easy ones, like basic round engine covers with only 2 or 3 bolt holes - well they are not too bad.
Petero - you will probably need to go to US or UK ebay to get these gasket sets. Would also be worth ringing RB Imports for some tips on suppliers.
- peterodactyl
- Bike: ZXR400
Thanks for the replies. I have gasket paper so that's no worries. I'm more chasing the rubber gasket for the cam cover and the spark plug well o-rings, as well as the rubber gaskets for the head bolts.
I might have to look overseas.
- timmyrocks
mate try RB imports on 02 95243177 they should have them or point you in the right direction.
if thats no luck try emailing Rick Oliver from england he is a wizz on the honda 400's and may stock parts for the zxr's
r.oliver@mtxnet.co.uk
or even this site is good and they should be able to give you some suppliers
http://www.400greybike.com/forum/index.php
hope this helps you out mate
Team Crash "09"
WR125 2004 Husqvarna
Team Crash "09"
- mike-s
It's a lot easier if you get the item, clean the sealing face, then spray it with something like cooking oil and cleanly press it down onto the paper sufficiently hard enough to leave a slight crease. Oil leaves a mark as well as the crease, and your then only as good as your skills with a pen and stanley knife.Gosling1 wrote:tracing a gasket for a cam cover, with all the small bolt holes - is about as much fun as having one of those small umbrellas dragged down the inside of your JT after a footy trip to Surfers !!![]()
- peterodactyl
- Bike: ZXR400
I ended up getting them from a shop called "Cradley's Kawasaki" in the UK.
the global village is a wonderful thing eh ??
