HELP!
- Bike: ZX7R
HELP!
You know when you read on a packet or website in this case "*note, professional installation required" and you say to yourself, nah i can do that, piece of piss.
well...
I just got a pair of valdermoto peg adjuster plates.
sounds pretty simple right?
my problem is i cant get the bike to select 2nd anymore.
This as you can imagine, is a bit of a problem.
Anyone got the majic answer to this problem?
And before you say put it basck as it was, that doesnt seem to do it either.
As far as i can tell im not getting the rod length right.
if someone can even just tell me the standard length would be great
as i commute on my bike, so any thoughts tonight would be great.
ment
well...
ment
- Ratmick
- Team Hornet
Re: HELP!
I can help if your bike is ZZR600...is it?Ment wrote:if someone can even just tell me the standard length would be great
ment
- Steve_TLS
- Bike: Scooter
re: HELP!
You definitely got the right one for your bike?
The rod length typically only adjusts the lever height (although it can have an affect on the shaft movement if an arm is way out (say the shaft arm is outside 4 to 8 o'clock)
The distance from the centre of the peg to the centre of the rose joint will affect the shaft rotation.
It might be as simple as rotating the arm on the gear selector shaft to get the correct ratio and lever height and then adjust the rod last to fine tune the lever height.
Steve
re: HELP!
from centre of joint to joint 217mm
from lock nut to lock nut 166mm
sean
life half lived is no life at all
[url]http://tinypic.com/k85zd.jpeg[/url].
01 ZX9R (Red ofcourse!)
re: HELP!
I know this is a silly question but you are trying to get it into second while you're riding the bike aren't you? If you're trying to do it while the bike is stationary the positive neutral finder won't let you.
- Nanna10r
- Team Ninja
Re: re: HELP!
I just assumed you'd riden it, Ment ya Rabbit I think you coulda earned your self a new nickname here.Ment wrote:Mick i think its safe to say im a dickhead.
that didnt even occur to me, just went for a spin around the yard, and all systems are go.
Cheers for that mate
Lemme think "Bushie" short for Bush Canic ?.
"Jerry or JB" for Jeremy Burgess the best damn bike engineer alive or ...... anyone have any ideas i think it warrants a new "Monica"
Cheers Brett
- Bike: ZX7R
re: HELP!
safe to say i really deserve any name you guys can come up with.
In fact we can run a competition.
I'll come around and service the bike of whoever comes up with the best name...
Seriously tho, it wasnt just the positive neutral finder.
i was riding the bike around last night with no joy.
it was a combination of what angle i was attaching the rose joint to the spline
last night (i was using the light from my mobile phone),
then when i started mucking about this morning i just naturally put it the right way. and didnt even think that i should ride it.
now for a hundred other excuses...
ment
re: HELP!
Don't worry mate, the only reason I thought of it was cause it caused me the same sort of grief till I figured out what the problem was...plus I have an intimate knowledge of how it works after the rebuild of the 9's gearbox
I'm just glad it was an easy fix for you
