ACELORATOR STICKING
- 2008ninja
- Bike: Ninja 250
ACELORATOR STICKING
Hi all, was looking for help with my accelorator. seems to sticking on a not snapping back, it feels loike i have gotten free cruise control, NOT GOOD ,
have pu;;ed the assembly apart and i think the cable might be stretched? can this be possible or is it just a simple adjustment issue? any help would be appreciated , Cheers.
Slow in Fast out. " thats what she said "
- Blurr
Re: ACELORATOR STICKING
doubt you would have
a stretched cable on a new bike. Is there any free play in your throttle? You could of over tightened it at the adjusters causing a slight pull on the thottle when he bars are turned
- 2008ninja
- Bike: Ninja 250
Have not adjusted it at all and have no free play what so ever....
thanks blur
- photomike666
Have you done any mods? Exhaust (flapper valve cable?), crash knobs (Rubbing on throttle cable/mech), or simple moved the cable to where is snags. It sounds more like a cable routing issue than cable adjustment.
Naked Twin
Check that it isn't the grip. I had a sticking throttle on my old zx7r. It only ever stuck after I had tied it down on for taking to the track (good place for it to happen!) and it was always due to the grip being pulled by the tie down.
Make sure the grip is clean and not binding at all.
Nick
Nick
- Glen
Back off the adjusters so you've got some free play. If it's wound up so that there's no play for some reason the throttle backs off really slowly.
- Blurr
You beat me to it Glen.
Yep you should have a little free play otherwise it does pull when you stretch the cable in any shape or form.
Other than this try some Silicon spray down the throttle cable and housing. Might be sticking slightly.
- Glen
I think I should wind mine right up on the tracky so it doesn't back off at all.....Blurr wrote:You beat me to it Glen.
- Blurr
Glen wrote:I think I should wind mine right up on the tracky so it doesn't back off at all.....Blurr wrote:You beat me to it Glen.
Or you can play with the nut adjuster near the tank area achieve alittle more size and firmness
- Glen
I think you might be on to something.....Blurr wrote:Glen wrote:I think I should wind mine right up on the tracky so it doesn't back off at all.....Blurr wrote:You beat me to it Glen.
- 2008ninja
- Bike: Ninja 250
Thanks for advice guys. Have wound it back a bit this morning and have a bit of free play now but will go further so its 100% . Didnt start at all this morning till i half fixed it.
