2006 ZX10R Instrument Panel
Mad RS
Post by Mad RS »
Hey Peoples,
I have looked through my service manual several times but can't find an answer. On the instrument panel what is the top left amber light for?? It's not the oil light so I'm not too worried. It comes on in the upper rev range around 11,000rpm. It's not a shift light is it??
Any help is much appriciated
Chris
Run what ya brung...............make damn sure you brung enough!!!
Re: 2006 ZX10R Instrument Panel
Mad RS wrote:It comes on in the upper rev range around 11,000rpm. It's not a shift light is it??
Yep :D And from memory you can adjust it should you feel the need. Im sure it is in the book somewhere but I could be wrong :)
Hold both the REset and Menu buttons this will send the needle to your current shift light point.
Then press the reset button to move it up. You keep going to the end of the Tach before it will fall inot the lower rev range area and start the cycle again.
Not sure why you would lower it though ;) :D
and if you peress the mode button while in that adjustment mode, you can change it from bright, to dim, to flashing and to Off. 8)
Mattjin
Post by Mattjin »
Not sure if this is widely known but screwing around with the Z1000 instruments I found that if you are on the ODO, holding down Mode and Pressing Reset lets you change between KPH and MPH, as well as either C or F for temperature, or any combination. Probably works for all of this type of instrument.
meh...shift lights...who needs em' ?
i shift by feeel ! :lol:
