10R tyre profile
- zx-10r
10R tyre profile
I just got a new rear fitted and its 190/50 when the stock one is 55. The last tyre i had on there was the same (55). Just wonder if there is any problems with having this tyre fitted. Thanks.
Let the good times roll.
- Blurr
Re: 10R tyre profile
no, no problem at all.
You will hardly notice a difference.
It may turn a little slower but not that you will notice much on the road. If you do just drop the forks through 5mm
- zx-10r
thanks blurr. That was my feeling too. On the road no problem, at 250km/h on the track is different
danzx10r
i have to disagree. i have tried a 50 on mine and thought it was really average. being a flatter tyre aspecially when it weares down. i found change of direction was more difficult
danzx10r wrote:i have to disagree. i have tried a 50 on mine and thought it was really average. being a flatter tyre aspecially when it weares down. i found change of direction was more difficult
can i get some riding lessons from you mate?
ive tried both on my zx10's road and track, could never tell a difference.
- MadKaw
- Administrator
If you wear the sides down first, you don't have that problem..
All manufactureres measure profiles differently so the profile numbers don't really mean a lot as you can't really use em to compare across brands. The shape and type of tyre is more important than the profile numbers...
I've used 50 profile to 65 profile rears and am currently using a tyre that has no profile on it just the diameter - its 650mm..
They all work..
They all work..
- Maccarocks
I have compared the differences of profile on the tyres at the island, as I work in the tyre department, and they do change significantly...!!
As in a 190/50 compared to a 190/55 you can clearly see and measure the difference..!!
The 50 is much flatter and will definitely not offer the same corner grip when leaned over..!!
If you had a 55 on and now have a 50 on, chances are you have just lowered the rear of your bike 4.75mm (9.5mm in total)
Which I agree with Blurr and Madkaw, is not much and on the street you wouldnt even notice it, but at the track you would, and the shape / profile of the tyre is definitely not aimed at faster cornering.. it is way less 'Veed'...
This is why the race tyres are 60 - 65 profile...!!!
Macca
Macca
Maccarocks
16' - Z1000 (Road)
16' - Z1000 (Road)
I disagree with the majority..
after recently changing from a lifetime of 190/50's to a 190/55 profile in a Metzler M3 I have to say the difference in height is dramatic..even to the point where the stand seems a few cm's shorter when I park the bike, it is also noticeable when riding the bike..but I wouldn't say it greatly affects the turn in performance of the bike..
I have become a 190/55 fan though..
- Maccarocks
Hoffy, you are agreeing with me..!!!
I also say that there is a big difference between 50 profile and 55 profile..!!
You can easily see and measure this difference..
I agree with Blurr and Madkaw on the fact that using a 50 on the street, you probably would not notice the difference at all...as none of us should be cornering that hard on the street anyway...!!!
Macca..
Macca..
Maccarocks
16' - Z1000 (Road)
16' - Z1000 (Road)
- MadKaw
- Administrator
I generally go with higher profiles tyres for the ride height, but as I said, shapes and profiles vary across types and brands..
for example...
http://www.michelinpowerone.com/en/la-t ... ofile.html
What tyre did you get.?
for example...
and a 190/55 dunlup rubbed under the Hugger of my o4zx10r and when i stuck a 190/50 M3 on it didnt. But the 190/50 Rennsport did touch it.
also when you stick on a pilot power rear, the side wall is angled out (almost liek tyre is too wide for the rim) stick a 190/50 M3 on and the side wall sits vertical. almost like the tyre is too thin for the rim. all on the same bike.
Lets not get started about tyre pressures.
Oh and the Handout that dunlop gave out at the Wakefield FX round showing the external measurements of the old GP racers and newer GPA 190/55/17 race tyres, and how each was different in height.
- MadKaw
- Administrator
yes, and the Dunlop GPA is 6mm smaller than the new 211 gp in the same size..
MadKaw wrote:yes, and the Dunlop GPA is 6mm smaller than the new 211 gp in the same size..
Oh noeS!!!!!!!!!!!!!!!
How did we ride at WP with a skinny tire????? Somebdy think of the contact patch!
Were these measurements taken when the tyre is new? half worn? mounted to rim? with what air pressure??
oh won't somebody think fo the children!
- Blurr
cant say I noticed at Winton.
- MadKaw
- Administrator
The new 211gp is actually 6mm taller (3mm ride height) but 9mm thinner than the gpa of the same size...
