My dads kwaka EL-250 is having some sort of issue starting up... its when you press the ignition button the starter motor wont engage the engine and start up... all it does is spin the gear...
I have tried spinning the starter motor with the crank case off and the gear behind the crank is the only gear that spins other than the starter motor and the one in between both of them...
I have a supplement manual that tells me jack and now am going crazy because not even google is helping me...
apparently this is the same motor as the ZZR, i dont know all i do know is that i have a cranky dad and no idea on how to fix it
PLS HELP!!!
