Sprockets and chain
StuMiller
State: Tasmania
Sprockets and chain
Post by StuMiller »
How hard is it to change a front and rear sprocket as well as put on a new chain? Any special tools required? I've got the standard range (socket set, shifters, etc)...
Any threads that can assist as I'm thinking of changing the the front sprocket and going down a tooth for better take off?? (I'm pretty sure that's right) and less top end speed?
Any help is appreciated.
Cheers.
2007 ZX6 - Road bike
Re: Sprockets and chain
Robracer's guide was pretty good....
http://www.ksrc-au.com/phpBB3/viewtopic ... 21&t=26114
Stace
Team Bolt
Team Bolt
Post by Stace »
Reasonably easy job mate. The only issue could be cracking the retaining nut on your front sprocket. They can be bloody tight.
I had all sorts of trouble pulling mine off (no smart arse comments please). In the end we used a big breaker bar with about a 1.5 metre length of pipe on it. I swung of the end of that while a mate sat on the bike with his foot firmly on the brake.
Stace wrote:Reasonably easy job mate. The only issue could be cracking the retaining nut on your front sprocket. They can be bloody tight.
As Stace has said, some are stoopidly tight. When i did the Zed we had the breaker bar on and it was lifting the back of the bike up - with 95kg ON the bike. If you cant get it go to a tyre shop or good workshop, they will whip it off for you no problem. Then you can go home and complete the job.
If you have a compressor, that usually gets the front sprocket off, don't use this on the rear sprocket!. A chain tool works wonders. Splitting the chain = grind off rivot and punch out the pin (chain tool or centre punch). Putting the plates back on the link is a bitch unless you have the correct tool and compressing the rivot is also better with the correct tool. I got a chain tool for $90 that does each step and turned a 2 hour job into a 10 minute job.
StuMiller
State: Tasmania
Post by StuMiller »
Where can I buy a chain tool from?
green10 wrote:Where can I buy a chain tool from?
Most good bike shops, do you have an MCA type supermarket in Melbourneistan
StuMiller
State: Tasmania
Post by StuMiller »
Don't know, I live in Hobart......there is a good bike in town so I'll drop in and check it out. :D
Cheers!
green10 wrote:Don't know, I live in Hobart......there is a good bike in town so I'll drop in and check it out. :D
Cheers!
From memory there are a few shops all close together in Hobart - one of them surely would have one. I have had mine for 10+ years now so they are a worthwile investment.
Stace
Team Bolt
Team Bolt
Post by Stace »
photomike666 wrote:If you have a compressor, that usually gets the front sprocket off
UMMMM Mike, A compressor won't do SWA without the rattle gun to attach to it :lol: You'll need a big arse compressor and rattle gun though. The $100 specials won't even blow wind up its arse (No pun intended)
yup...ze bolt man is correct
when i got my compressor I also got a larger (heavier...bigger whatever) rattle gun from Total Tools
its rated at 280 ft/lb and I havent found anything yet...it wont remove :kuda:
Stace
Team Bolt
Team Bolt
Post by Stace »
Smitty wrote: yup...ze bolt man is correct
I got something you can give it a work out on Smitty :twisted: XXarcade.gif
Most good engineering supply shops have chain tools.
Try Blue Point 1/2" drive impact gun @ 780 ft/lb. It will even remove Staces bolt :shock:
I got a $150 compressor from Supercrap Auto, came with a free tool kit including a rattle gun - this has never failed to remove a front sprocket (CBR600 several times, Zx10r couple of times and one of Eelco's bikes either Crim or Gixxer). Last front sprocket change two weeks ago, compressor is around 4 years old
lifeofcrimeguy
Post by lifeofcrimeguy »
photomike666 wrote:If you have a compressor, that usually gets the front sprocket off, don't use this on the rear sprocket!. A chain tool works wonders. Splitting the chain = grind off rivot and punch out the pin (chain tool or centre punch). Putting the plates back on the link is a bitch unless you have the correct tool and compressing the rivot is also better with the correct tool. I got a chain tool for $90 that does each step and turned a 2 hour job into a 10 minute job.
Getting vice grips which fit snuggle between the two pins has my plates on in seconds
See here, young man,
From Walgett to the sea,
-- Banjo Paterson
LMFAO
