EXHAUST VALVE SERVO
- Baddie
EXHAUST VALVE SERVO
Hello Legends,
I’m about to finish off my exhaust system without the need for an “Exhaust valve servo”, should i remove it and install one of these?. (Zx10r Exhaust Servo Eliminator)
http://cgi.ebay.com/ebaymotors/ws/eBayI ... MEWAX%3AIT
Also I still have the “Cat” installed on the end of the headers, is this going to make much difference in performance?
http://superbikesource.com.au/
For aftermarket racing products, from Annitori Quickshifters to Race fairings.
http://tarmactalk.com/forum/forum.php
Re: EXHAUST VALVE SERVO
What bike ?
In a nut shell, you will need the servo buddy if not installing it on new system, yes..
- tim
I'm gonna have to handle this very soon also once I get the time. No Cat tho.
Will the "FI" light just flash without it? Is that all the servo buddy does?
- Dingus
Grab the servo buddy, not the servo eliminator from Ivan's Performance. The one you linked is what I have in my ZX10R gen 3
- tim
Just read the description of the listing.... yup, that's all. I'll have to have a look and see how much work is involved in removing the servo motor later if I'm gonna leave it there...
- MrWasabi
- Team Kuda
servo motor should be a piece of piss to remove, its under the seat and the bolts can be seen under the wheel arch.
- MrWasabi
- Team Kuda
Hey mate,tim wrote:Just read the description of the listing.... yup, that's all. I'll have to have a look and see how much work is involved in removing the servo motor later if I'm gonna leave it there...
If you are buying a servo buddy, would you be inclined to dissect it? i have been trying to backward engineer it for some time now and have the basic gist of it.
I know its got no software loaded on to it and that its purely an analogue device, so it would be a matter of finding out what components are soldered onto the board and replicating it...
I think what it does is take the input signal from the ECU to move the motors and converts it to a signal which is fed back into the ECU....
- Dingus
Jeremy (the guy who makes servo buddy) posted on the ZX10R.net forums what he uses to build these boards with. I will have a look around to see if I can find his post.Hey mate,
