ZX10R issues
chunny
ZX10R issues
Post by chunny »
OK, So now the bade is getting some serious K's, I'd like to know if there are any issues that I should be lookng out for on the 06 - 08 ZX10's
chunny
Re: ZX10R issues
Post by chunny »
So the ZX10R has no issues??
Re: ZX10R issues
not in that lasd 7 hours no.
Re: ZX10R issues
how many KMs do you call serious KMs?
keep changing the oil and getting the valves checked every 24000, and i cant see why it wouldn't pull the tonne (100,000km) plus easily.
Probably most important thing is to check the cam chain tension, the spring in the tensioner becomes weak after a while.
you can just buy a new tensioner and whack it in (5 min job) as long as your cam chain is still good.
Re: ZX10R issues
Nothing really.
BTW the 06 / 07 were the same model (twin underseat exhaust) and the 08 / 09 / 10 were the next model.
Wattie has been racing an 06 / 07 this year with very few issues. The engine is stock with slip ons only and the suspension has been upgraded with ohlins rear and custom rebuilt forks..
I think the only known issue is, its ugly.. :-)
Re: ZX10R issues
MadKaw wrote:I think the only known issue is, its ugly.. :-)
And has a big load carrying capacity! :lol:
Re: ZX10R issues
06-07 has some reported charging issues, generally Stator/Rectifier related. Low end revs in 1st gear can be a bit choppy, TRE can help significantly. Turns best with a 190/85 (as opposed to 190/80) and a 3mm washer to raise the rear end a bit.
Re: ZX10R issues
photomike666 wrote:06-07 has some reported charging issues, generally Stator/Rectifier related. Low end revs in 1st gear can be a bit choppy, TRE can help significantly. Turns best with a 190/85 (as opposed to 190/80) and a 3mm washer to raise the rear end a bit.
you mean 190/ 55?
of and my rear is back to stock height.
better drive 8)
Re: ZX10R issues
MadKaw wrote:I think the only known issue is, He's ugly.. :-)
Corrected....again Dave FFS
Re: ZX10R issues
you mean 190/ 55?
better drive 8)
Yes I meant 55, must be old or tyred :roll:
mercho
Re: ZX10R issues
Post by mercho »
Haven't had any issues with the stator in my 07 zx10r and it has just clocked over 24000ks. As for the low end issues, I haven't experienced that either, but I do have a TRE so that could be why I haven't noticed anything...
I don't have the "ugly" issue that Madkaw stated either, i think the gumby is a great looking bike! :kuda:
Brad
07 zx10r SE - 99 r6
My Photography Site
shinya56
Re: ZX10R issues
Post by shinya56 »
haven't had any issues with the stator in my o6 zx10r as well when i had it bike done 20,000kms when i sold it,only issue that the
rocket cover gasket did leak at top right hand corner, and the timing plugs o-rings leak oil there as well.found the bike great to ride
just thirsty when you crack the throttle wide open :kuda:
