Hi everyone. i got a zx2r c model
i hv no idea wat bots to open to bleed the air out. after draining the coolant... i looked up on the owners manual that is uploaded on this website but it hasn't been scaned really well so can't really see the second bolt... whic is the cylinder head...
i was wondering if someone can upload a picture or something... dat will show which bolts to open...
oh besides my coolant is really brown... is dat bad??? like permenantly bad?
i would greatly appreciate your help
how to bleed the air out after draining the coolant
- zxsixr03
Re: how to bleed the air out after draining the coolant
U should have a small bolt above the water pump...
Also u don't need to bleed the air out once u drain it and re fill squeeze along he rubber hose to push any air out.
Once filled up start and let the bike run and warm up to allow the thermo to kick in leave the rad cap off and watch for the flow over the top of the rad this will also flush any air out, top up if needed.
The brown coolant no idea mines only ever come out green or red same as it went in...
Brown coolant is a sign of rust, & yes there are metal components in the radiator
that is some great advice "zxsixr03" i was really worried about bleeding the air out... but now I will just do it with no drama. tnx mate
Dats gonna damage the engine isnt it?? if i change the coolant would that fix it??? or is there any way dat i could fix it?robracer wrote:Brown coolant is a sign of rust, & yes there are metal components in the radiator
