HELP with clutch issue zx9
- z900/zx9
Well i got a set of barnett carbon fibre plates with steels and springs.Fitted them soaked in oil first as instructed then fitted friction first then steels etc and friction last.adjusted cable then started her up.Well Clutch not disengageing slipping like a fuck just up the driveway.What the fucks going on any idears ???.
- MadKaw
- Administrator
Re: HELP with clutch issue zx9
Yep, its pretty simple...
You've done something wrong..
Pull it out and do it again, this time correctly..
Check the clutch pack size, or stick a venier on em to make sure its all correct. also make sure all the metal plates are in the same way (that shouldn't cause slipping though).
Did you put the clutch pull rod (the bit the arm in the cover activates) inside the clutch end plate before tightening up the springs.? it fits in after it but won't work too well.. I'm sure thats not it, but its the simple things that get overlooked..
- z900/zx9
All fixed, confusious say man over 49 years old should wear glasses when putting in clutch plates
