This is mostly me thinking out loud and getting some second opinions in the process here. Basically my GSX250 has valve problems again. When i bought the bike the problem was the past owner had let the valves go unadjusted and promptly burnt the shit out of one of the exhaust valves & seat and from memory didn't do much in the way of kindness to the other exhaust valve seats, hence i got it for a song as they bought it with the intention of fixing up, but it sat in their shed for 3 years before they sold it to me.
I replaced the shot valve, lapped it (probably should have gotten it cut at an auto-mech's down the road in the first place) and it "looked" like it was getting a good seal despite this damaged exhaust seat. Fast forward 4kkm or so to now and i did a compression check yesterday and got a grand total of 90Psi left & right. Compression check shows that it is likely valves again as squirting a few ml of 30w oil in there did nothing to improve compression. Aside from some headaches with tuning, the rest of the engine is in pretty good nick (new camchain, cams and followers are in great condition with no marks whatsoever, piston/rings/barrel seem good too).
I have found a engine at a wreckers about 200km away that is in an "unknown" state as it was sitting in the past owners back yard (in the bike) for 5-6 years before he sold it to the wreckers to get rid of it. I have been told i can get the entire engine as-is for $150 as they genuinely do *not* know the state of it. It could be a gem of a head but with worn barrels, or could be perfectly ok all around. Now I know it's a bit of a gamble in buying this engine just for the head and I'm looking at some other wreckers to try and just find a head, but thus far none seem to be quite as cheap as this one. For example one of the wreckers i called was after over $250 for a head that was on a bike that got all of 60/65 psi
If i can't get a half reasonable head a lot closer than this one, would it be worth just getting this donk for the bits i need and parting out / keeping the rest for spares/ the bin? I am asking as i suspect that the seats in the current engine are too far gone to be of any use, and despite only getting an engine reconditioner to only cut the seats, I imagine with the cost of labour and parts (likely new valves as well as the seats) i would be up for a small fortune pretty quickly.
So yeah, failing finding another alternative head for cheap, think it's worth the gamle?
[edit]Just for further info i have taken the head off the current engine and there doesn't appear to be any damage to the face of the valves this time around, unlike the last time, doesn't mean the seats arent totally ratshit though[/edit]
