thicker oil?
- greg
thicker oil?
Motal 5100 ok to use on the zx12r??...reckon this bloody knocking(sounds bottom end) noise
could be oil too thin esp with this heat????? last oil and filter change abt 3 months ago...found out mech used synthetic oil used am i better off have 5100 being a thicker oil as the old girl now over 100000ks..any feedback much appreciated...hoping the prob could be that simple..or maybe i am just kidding myself..just trying to elminate the prob b4 l start spending the big bucks$$$$ Any suggestions would be much appreciated.
Re: thicker oil?
When did you last have the throttle bodies balanced? Might help get rid of some of the knocking around.
Re: thicker oil?
There are also several viscosities of 5100. I have used that in all my bikes for the last farkknowshowmany years with no issues and 200K+
- Strika
Re: thicker oil?
Mate, if the bottom end of the 12 suddenly goes quiet....then you have problems!!! It's a kawasaki mate, they sound like a tin box full of nails when new!!!
- Jonno
- Mobile Chicane
Re: thicker oil?
And 12Rs are the quieter engines
I use Motul 5100 in all my bikes.
Re: thicker oil?
Motul 5100 is the go for a barge Greg. MickLC is on the money about a throttle-body balance as well......
- greg
Re: thicker oil?
MickLC wrote:When did you last have the throttle bodies balanced? Might help get rid of some of the knocking around.
:Gosling1 wrote:Motul 5100 is the go for a barge Greg. MickLC is on the money about a throttle-body balance as well......
Jonno wrote:And 12Rs are the quieter engines![]()
Thanks Guys for this info much appreciated.
And thanks for calling me Wattie on this matter.
will let you know outcome.
Greg
Re: thicker oil?
If it helps Greg, my 9 had 130K plus on it - 98% of those done with Motul 5100 keeping things slippery. That was until Mr Camry driver decided I needed a Z1000
- greg
Re: thicker oil?
Thanks PhilPhil wrote:If it helps Greg, my 9 had 130K plus on it - 98% of those done with Motul 5100 keeping things slippery. That was until Mr Camry driver decided I needed a Z1000
- greg
Re: thicker oil?
Hey Guys....
Changed oil filter and used motol 5100 20WD...knocking noise still
don't know if attached video any help...have got three different reason from 3 x mechanics.
1 says gear box
1 says clutch
1 says not sure , might be bottom end main bearing....
might just to bite the bullet and pay for labour cost to find out ..
Bike still running well and knocking noise occurs after bike warms up...continues whilst in idle as well. If i ride for more than say 20 mins,,fans kicks in and noise suddenly gone..
.to me thats not main bearing
i don't know am i wrong?
Any feed back would be appreciated before i make any final decisions.
Cheers Greg
1 says gear box
1 says clutch
Cheers Greg
[The extension wmv has been deactivated and can no longer be displayed.]
- Smitty
Re: thicker oil?
Greg
got yr msg (like late after a meeting) will call tomorrow
looked at the video but cant quite make it out
there is a noise but its sounds a bit like a mix of a dingding 2 stroke and a main drive chain
is the noise the same on the other (clutch) side?
and does it change whether in or outta gear?
does it sound like its near the water pump..??? ( I has my suspicions)
Re: thicker oil?
anyone using 7100? thought fully synth would be the way to go.
- greg
Re: thicker oil?
Hey mate..Smitty wrote:Greg
noise not the same on clutch side..ruled olut the clutch
does not change when in or out of gear
what stumps me is that riding for the first say 10 minutes no noise....then suddenly comes on and is progressingly getting louder...have only been riding to and from work say 10 kms each way over the last 2 weeks.....
I know Gosling1 and Phil are also stumped....
wat r ur thoughts abt water pump????.
- greg
Re: thicker oil?
Gos seems to think maybe cam chain tensioner on its way out or already gone...seems to make sense..correct me if l am wrong...would cam chain noise be top end
or would noise go right through motor??
- Strika
Re: thicker oil?
If the sound clarity is accurate, I don't believe it is a cam chain. They tend to be more tinny than that. That sounds like something is not tight somewhere, but without walking around it physically and listening I am not able to diagnose it accurately. But, it could be a knackered clutch basket finger, could be a water pump, could be a loose flywheel weight or pick up. But it could also be bottom end or box related. I think a little pull apart will tell you all you need to know.
Have you listened to it from a variety of positions with a screwdriver???
