Motoplast frame
Eastoe
Bike: GPz750
Motoplast frame
Post by Eastoe »
Sorry. It's a suzuki.
I've just bought a Motoplast frame for my GSX1100 race bike.
It has a really long steering head 220mm so I need a long steering stem.
Is anyone aware of any bikes that may have come with a long steering head stem?
Would need 260mm plus.
Re: Motoplast frame
Richo - best bet would be to have one turned up and press-fit into whatever lower clamp you want to use. I checked all my triple-clamp stems tonight (big box) and nothing even close to 260mm long......all of them were much shorter than that.
Any engineering shop will be able to turn up a custom stem, and should be able to press it into your lower triple.....
Re: Motoplast frame
Jesus Gos, I wish I knew half as much about muddboiks as you do mate!!!! 8) 8) I guess all those years of being forced to work things out for yourself have paid off!!! :D
How's the MFP12 project coming along by the way mate? :? Been too tied up with the thirty thousand other jobs you got on??? :lol:
Re: Motoplast frame
yeah marty, he's getting the 750 triple going by christmas :P :lol:
Re: Motoplast frame
Strika wrote:.......Jesus Gos, I wish I knew half as much about muddboiks as you do mate!!!! 8) 8) I guess all those years of being forced to work things out for yourself have paid off!!! :D
How's the MFP12 project coming along by the way mate? :? Been too tied up with the thirty thousand other jobs you got on??? :lol:......
easy there big fellah, I reckon you have forgotten more about bikes than I will ever know ;)
MFP12 is currently regoed and on the road - all back to *normal* sort-of, running blue nose-cone and l/h side fairing, OEM r/hand side, tank cover and ducktail. It almost looks like a normal motorbike ! :lol: - but it is great to be back and riding it - I knocked up another version of 4th Dimension heli-bars, these ones work way better than the first version and very comfy. Only some small mods needed to this design - and the 3rd version will be perfect !! :kuda:
So much on at the moment, but a couple of projects are humming along nicely......winter can be good like that ;)
Eastoe
Bike: GPz750
Re: Motoplast frame
Post by Eastoe »
Gotta be locky sometimes.
The guy I bought the frame from found the bottom triple clamp so looks like the stem problem is solved.
paul w
Re: Motoplast frame
Post by paul w »
From memory, the frames were brought in by the Ducati mob at Gowanloch's in the 80s.
They might have a bit of info, or even contacts.
Worth a phone call, anyway.
Re: Motoplast frame
Ian Gowanloch spends more time drinking red wine these days at Adelong than he does playing on those temperamental italian mistresses...... :lol: - but he may still have some odd bits 'n pieces kicking around for one of these ?
Frame looks good Rich - but whats the go with the seat tubes ?? One looks way longer than the other ?? :shock:
Eastoe
Bike: GPz750
Re: Motoplast frame
Post by Eastoe »
The seat tubes are removable and adjustable for length.
Must be for lard arses and skinny arses.
Only one seat tube is on the frame.
fezzick
Re: Motoplast frame
Post by fezzick »
Here's what it might look like when it's done. This one has a Z1 engine.
https://www.facebook.com/media/set/?set ... 3e7&type=1
I started out with nothing and I still have most of it left. Phil
www.halfofmylife.com
