Rear tie down
StuMiller
State: Tasmania
Rear tie down
Post by StuMiller »
I'm looking for a rear tie down that has a wratchet and actually cover the tyre itself. I've seen these a few times, but not too sure where I can get one.
I'm using a Kaneg trailermate for the front and want something strong and sturdy for the back end, without attaching anything to the frame or rear footpegs on the bike.
What is available and where can I get one?
2007 ZX6 - Road bike
Rear tie down
Called a tyre down.
There is also a strap version. Maybe Andy straps make them??
Team Monster
Re: Rear tie down
Post by Disco »
Wattie wrote:Called a tyre down.
I have the strap version and love it :kuda: ....I bought mine of Triway of here but last I heard they are no longer available because of patent issue's :? .....
Re: Rear tie down
This is them
Pretty expensive but they are good
http://www.ebay.com.au/itm/Motorcycle-r ... 23115f35b6
You can actually achieve the same result using two tiedowns but a bit more fiddly.
Re: Rear tie down
I have a few of the steel straps from http://www.kyaracing.com.au/ for roadbike and the chooky versions, no need to strap the forks down any more as long as you have good front wheel chock (trailermate), I do still strap the dirtbikes forks when on the Yoot.
To give you an idea, I had 2 roadbikes in my trailer and the chooky on the yoot from Adelaide to Gingers Creek NSW then to EC and back to Adelaide and for most of it I only used the Tyredowns and no fork straps, on the way from Adelaide I only lightly strapped both bikes forks but didnt bother on the way back.
Makes it so quick to get bikes loaded and unloaded.
Re: Rear tie down
They're cool and double as Armour :D
Jonnymac
Re: Rear tie down
Post by Jonnymac »
Yep I have the tyre down for my trackbike.
Really good would highly recommend the bike doesn't move at all and you don't have the problem of compressing your front forks for long periods of time.
You can pick them up from most bike shops you should be able to get them cheaper than that eBay price, mine was a lot cheaper mind you it was probably 5 years ago that I bought it!
StuMiller
State: Tasmania
Re: Rear tie down
Post by StuMiller »
Jonno wrote:I have a few of the steel straps from http://www.kyaracing.com.au/ for roadbike and the chooky versions, no need to strap the forks down any more as long as you have good front wheel chock (trailermate), I do still strap the dirtbikes forks when on the Yoot.
Yep, that's them. Any idea on pricing?
I'm thinking of bringing the bike over to Melb on the trailer for a ride/ride day and want the best tie/tyre downs I can get.
Many thanks all.... :kuda:
Re: Rear tie down
StuMiller wrote: Yep, that's them. Any idea on pricing?
Cant remember Stu, around the $200 mark for the roadbike jobs I think. Give them a call.
z900/zx9
Re: Rear tie down
Post by z900/zx9 »
I bought one last november and it was $150.00
