Oily brake pads
- stetto
Oily brake pads
I recently bought some 09 Zx6r calipers for my crim, but they came packaged in a plastic bag which was oily on the inside, I assume its brake fluid but its definitely slippery. The pads look like they r covered in this liquid, is it possible to clean it off or r these pads rooted now?
sent from my Android using Tapatalk
- Blurr
Re: Oily brake pads
Brake cleaner is your friend
- Blurr
Re: Oily brake pads
if they are not fully soaked that is
- tim
Oily brake pads
Taste a bit of the fluid, if it's bitter it's brake fluid.
Re: Oily brake pads
The pads can soak in the fluid, you say they were covered? Id chuck em, & Tim I dont think "tasting" brake fluid is such a good idea
- fireyrob
Re: Oily brake pads
I hope he hadnt been at a local swimming pool just priorrobracer wrote:& Tim I dont think "tasting" brake fluid is such a good idea
- stetto
Re: Oily brake pads
Rightio ill have a closer look and go from there, cheers
- tim
Oily brake pads
Fixedstetto wrote:Rightio ill have a taste and go from there, cheers
BoratJr36
- Bike: Ninja 250
Re: Oily brake pads
Go with blurr use brake cleaner then wipe with a rag works fine just test them befor goin high speeds and stuff.
It's always fun and games until someone gets hurt..... Then it's hilarious!
- timmyrocks
Re: Oily brake pads
Bin them, brake pads are chaper then a crash.
They may come good after some brake cleaner when cold but when they heat up may be a different story.
Team Crash "09"
WR125 2004 Husqvarna
Team Crash "09"
- mike-s
Re: Oily brake pads
That's true, i dont know about the bonding coming apart, but there's every chance some of the fluid has gotten deep inside the material of the pad, and it comes out when heated up by use.
- laidback
Re: Oily brake pads
timmyrocks wrote:Bin them, brake pads are chaper then a crash.
oldman
Re: Oily brake pads
Oil or brake fluid on brake pads has the oposite affect that you would think. It causes the brakes to grab locking the wheel. I would definitly junk the oily pads. The problem with brake pad material, (with the exception of ceramic brake pads) is that they absorb the oil making the pads soft and grabby. You can burn it off by riding with the brake on until it's hot only to have it resurface at the worst time, (next time you have to stop). Have a shot or 6 of Jim Beam with a fine brew of your choice and this will all become clear.
- stetto
Re: Oily brake pads
yeh i decided to bite the bullet and bin them, not worth it
