Zx-2r oil leak
Zx-2r oil leak
Hey guys. This zxr250c is my first bike so i don't know alot. So i figured id ask the best. I have had what I think is oil coming out of the left side of my bike out of the hole that goes into where the airbox is. I took the cover off and can see it happening. Any of you guys able to help me. Thanks
						Re: Zx-2r oil leak
reckon you can throw a pic on here? I think I can help, sounds like the stator cover, if so, a new gasket is about $25 at your door from ebay. Pic first though, this is just an assumption...
						Re: Zx-2r oil leak
also, what area of nsw are you from, if sydney roughly which part? If you're nearby I don't mind dropping by to have a look and give you a hand if you need it!
						Re: Zx-2r oil leak
Any help would be greatly appreciated. When i give the bike some revs. more of the oil/ whatever else is in it comes out of the bottem then comes out the side hole on the left side of the bike
						Re: Zx-2r oil leak
This may be a guess but have you checked your oil level? monitor it before and after a few rides and see if there's a change, to be honest, I've never seen oil coming out there, so I'm not sure what it is, but I've pulled the airbox off and everything, and under that angled tap looking thing,there's an inlet into the engine, though my thoughts was that it is some sort of breather...
						- timmyrocks
Re: Zx-2r oil leak
Yep that's your crank case breather that goes into the airbox.
Check your oil level, I foundif mine was at the higher part if the level I'd get oil there, if it was in the middle or just below it I got hardly any oil in the airbox.
Take a photo of your oil level while the bikes vertical
Team Crash "09"
WR125 2004 Husqvarna
						Team Crash "09"
Re: Zx-2r oil leak
When i rev the bike like i said , it comes out from the angled tap, the base of that tap is also broken, ( not all of it is attached to the base ) im not sure if i should start my bike and let it all come out.
						- timmyrocks
Re: Zx-2r oil leak
What's you oil level at?
Team Crash "09"
						Team Crash "09"
Re: Zx-2r oil leak
Just a bit below half on the glass at the moment.
						- timmyrocks
Re: Zx-2r oil leak
Pressurized crank case.... How bads the oil coming out? Able to video it at all?
Team Crash "09"
						Team Crash "09"
Re: Zx-2r oil leak
the first time it came out was fairly violent, poured out the side out the bike
