chain adjustment
MrFaulty
chain adjustment
Post by MrFaulty »
Hi, just tensioning my chain and I note there are graduation marks, I have never used these before, however, if I do, then there is a difference between the end of the adjustment part and the end of the fork for both sides. Should I use these marks or simply use a steel rule such as I have been doing in the past?
Thanks
ben
Re: chain adjustment
Technically, you should use the markers if they are accurate and even on both sides. Often however, they are not accurate. If so, then it's best to string line the bike, work out what the distance difference is and mark the swingarm with it.
EG: My race bike when I strung lined it, if I had the axle locked into the correct marks on each side of the swingarm, the wheel pointed slightly to the left. So, when refitting or adjusting the axle, I always add 3mm to the right hand side to ensure it is straight.
I hope that makes sense, I am back on painkillers and a little wobbly........
Unless you're going to string line it, then Japanese engineers put those marks there for you to use so why wouldn't you trust them and use them - they did design and build your bike after all. :? ;) Who's to say they made the swingarms the same length on both sides.
tim wrote:Unless you're going to string line it, then Japanese engineers put those marks there for you to use so why wouldn't you trust them and use them - they did design and build your bike after all. :? ;) Who's to say they made the swingarms the same length on both sides.
They designed and built Zero's too....
look how that turned out for them :lol:
Mad RS
Post by Mad RS »
I picked up a chain aligning laser and it seems to work perfectly. Cost about $80 and cut down aligning the chain to 2 min.
Run what ya brung...............make damn sure you brung enough!!!
Jonnymac
chain adjustment
Post by Jonnymac »
Where did you get your laser from?
Thanks
Nelso
Post by Nelso »
Don't trust them, most are inaccurate. Remember they are engineered to a budget and mass produced, so precision and accuracy is not as high a priority as profit. The best bet is to stringline it to make sure it's straight.
loubre
State: Northern Territory
Post by loubre »
Yep, on my ZR7 left is out by 3mm
2005 BMW R1200RT
2012 ZX6R
jefflthomas
State: Overseas
Post by jefflthomas »
just buy an old Beeser...no worries about these newfangled convoluted marked swingarms
'01 ZRX1200R ZR1200A1
MrFaulty
Post by MrFaulty »
Thanks everyone, chain adjusted properly and using the graduation marks would mean the the tyre is about 3mm out!! the japs should have paid more attention ;)
jefflthomas
State: Overseas
supposedly the back wheel's slightly offset on my ZRX1200 to accommodate the chain with the larger tyre than the 1100
oldman
Post by oldman »
The marks are close but off. Get a three foot lenth of angle aluminum, (90 degree) and run it along the chain and measure the distance between the angle aluminum and the front of the rear tire in comparison to the distance between the rear of the rear tire. Easy and cheap and it does not require batteries. Jim Beam is however a necessity.
jefflthomas
State: Overseas
now there's a good idea...wonder where i put that broken 4' level
oldman
Post by oldman »
Pictures for those such as myself who are mentally impaired.
jefflthomas
State: Overseas
how true are Kawi mags?...i've never taken a dial-gauge to 'em
