Friction point adjusment
zxsixr03
Post by zxsixr03 »
How do i adjust where the friction point comes in on the clutch (not the span of the lever) mine is less than a finger width from the bar so each stop light i have use 4 fingers and pull the clutch right to bar to get neutral or a quick stop with the clutch in if not right against the bar the bike creeps a lot....
Re: Friction point adjusment
Either the big serrated adjuster going into lever mount - wind it out.
Or at the clutch cover theres an adjusting nut and lock nut on the cable down there... you need to adjust it to pull the clutch rod a little more.
zxsixr03
Post by zxsixr03 »
Adjuster at lever just alters the free play in the lever, not actually where the clutch engages, i will try the other end..
zxsixr03 wrote:Adjuster at lever just alters the free play in the lever, not actually where the clutch engages, i will try the other end..
Um yes it alters both freeplay & clutch engagement..... its all relevent, it does the same at both ends
Ky jelly
