When I start the engine the choke is manully adjusted accordingly. The engine revs at 3-4000 and then idles down to zero and stalls.
I adjusted the clutch cable without any luck therefore, I suspect there is a problem with the clutch, so I disconnected the cable and manually operated the clutch with the engine running. The revs were at 3-4k, so I adjusted the idle screw down to 1-2k revs and when I manually pulled the idle lever back the revs reduced instead of increasing.
Is there any fault finding stuff I can do to help locate the problem? Or do I spray the choke adjuster and spring with WD 40 and hope?
What is your opinion?
Splitter
