tried starting it for about 15 minutes and flattened the battery. i'm at work now, i have to go back home and fix the bugger later
the bike was off overnight outdoors and this was at about 7am...
i 1st tried to start it by putting the choke on all the way and pressing the starter while turning the accelerator a tiny bit. clutch in and bike in neutral. the engine turned over a couple of times then it stopped.
i know that if the bike has has been running recently and i try to use the choke it won't start (floods it i guess?).
so anyway then i turned off the choke and tried to start it without choke. then tried lots of starts doing all sorts of stuff like turning the accelerator all the way (i heard somewhere that u do this if its flooded), part way, tried some choke, even flicked the fuel tap to "prime" for a second. a few times the engine turned over a little but it didn't catch on and start running
oh and the tank is 3/4 full.
anybody got any ideas?
usually my bike starts first time every time. the only time it won't is when i use the choke when its already been running recently, when that happens i can usually get it to go after about a minute.
