09+ ZX6R Akra link pipe gasket
Kermit
Post by Kermit »
Hey
If there any owners out there running akra link pipe on there 09+ zx6r, did your pipe come with a gasket that joins link pipe onto OEM CAT/Header pipe or did you re-use the stock gasket.
Yep but in didnt put it on. From memory of previous link pipes non of them had the gasket.
Kermit
Re: 09+ ZX6R Akra link pipe gasket
Post by Kermit »
Blurr wrote:Yep but in didnt put it on. From memory of previous link pipes non of them had the gasket.
So you used the stock gasket to connect the link pipe to the CAT pipe?
