Ignition Coils - does side matter
- Glen
OK so the genuine Kawasaki Ignition coils are two different part numbers, one for the left side ie cylinders 1 and 4 and the right side cylinders 2 and 3. The left one is $170 and the right one $160
The left one is in stock and I can get it now, the right one (the one I think I need) has to come from Japan and will be three weeks. I'm going to replace both just for the fun of it (heaven knows what else would you do with a spare $170)
My question is....can anyone see why I can't temporarily take the new left one and stick it on the right side. The terminals will probably be arse about but I think I'm smart enough to get that right.
Any help would be mucho appreciado
- Strika
Re: Ignition Coils - does side matter
If it has the same ignition timing, as in an even firing order, then it shouldn't matter I wouldn't think. The firing intervals would be the same for both coils wouldn't they?
It shouldn't damage anything to try...
- Glen
That's what I was thinking mate......if I blow up the CDI I'll let you know the answer to your last statement
- timmyrocks
I have done it before glen, on the vfr400. Only difference was mounting lugs and the terminals, but they were coloured so couldn't stuff that up, cable tie sorted out the mounting
Team Crash "09"
WR125 2004 Husqvarna
Team Crash "09"
- Glen
Thanks mate. I'll give it a shot. If you see a mushroom cloud spreading over kellyville you'll know I fucked it up.
No mushroom cloud yet...
- Glen
Don't worry dude if I go you go with me.hoffy wrote:No mushroom cloud yet...
- fireyrob
If u could avoid a major disaster tonight or tomorrow night Id appreciate itGlen wrote:Don't worry dude if I go you go with me.hoffy wrote:No mushroom cloud yet...
You on a promise Robfireyrob wrote:If u could avoid a major disaster tonight or tomorrow night Id appreciate itGlen wrote:Don't worry dude if I go you go with me.hoffy wrote:No mushroom cloud yet...
- fireyrob
Not on overtime. I hate disasters on standard pay
- jefflthomas
- State: Overseas
- Glen
That's correct, but assuming I can get leads 1 and 4 to reach cylinders 2 and 3 will it work ?
- jefflthomas
- State: Overseas
just buy one coil & use the plug wires off the old one if you have to...should be fine
'01 ZRX1200R ZR1200A1
- Glen
jefflthomas wrote:just buy one coil & use the plug wires off the old one if you have to...should be fine
Yep that's what I was thinking.
- Strika
Glen, I think I hinted at checking, but have you checked the ignition barrel and the kill switch to make sure they are not intermittently breaking contact? I'd hate for you to spend all this cash to find it's a dirty kill switch or a faulty ignition barrel or wiring!
