Quick suspension guide
- BlackRabbit
Hi guys have a quick suspension question. It's probably been spoken about many times before. I have a 2010 ZX10 and I weigh about 80kg all kitted up. What is a good starting point to work with on my factory suspension?  Clicks in and out and spring preload. Mainly road riding on rough shitty Vic roads.
Secondly. What is the best way to adjust the rear spring preload. The shock is really tucked away and hard to get access to. Shock I remove it or does any one know where I can get a decent C spanner that will do the job and won't butcher my shock ?
Much appreciate any feed back
10 ZX10 Melbourne
Start with clickers as the book says and work from there.
The springs should be about right for your weight.
Just need to set the sags. About 30mm from and read rider sag is a good starting point for the road.
If you need to adjust the shock preload without using the hammer and screwdriver method.
Then year rip it out and do it. C-spanners you can get at most bike shops.
- Baddie
Re: Quick suspension guide
http://superbikesource.com.au/
For aftermarket racing products, from Annitori Quickshifters to Race fairings.
http://tarmactalk.com/forum/forum.php
- Strika
BR, bring it over one weekend and I will set it up for you.
- Jonno
 - Mobile Chicane
Strika wrote:BR, bring it over one weekend and I will set it up for you.
Yep do it
Marty knows which end of the horse does what
- BlackRabbit
Too easy thanks for the offer. Will take you up on it soon. Thanks heaps
							10 ZX10 Melbourne
				DJ666
Is there a under seat toolkit? Should have the c-spanner?
Sorry just going off what came with my ninja 650l
Under seat toolkit in a zx10 won't have a c spanner. Too heavy
Hammer and screwdriver haha
- born green
Mmm i watched stu winton do that to my 10 at broady a few years agoWattie wrote:Under seat toolkit in a zx10 won't have a c spanner. Too heavy
Dont have that problem anymore, just turn the knob
96 ZX7R  roady
95 tickford XR6,
95 tickford XR6,
