third gear wont work?????zzr 1100 1996
- Bike: ZZR1100
it goes into gear & works with a slight bit of throttle but then it just sounds like it hasnt gone in to gear if you know what i mean.....i can slow down in it but just cant wind it out.i dont want to pay more to fix it than what i paid for it but i love this bike aswell so some knowledge of this issue would be great.
- MAXUMIS
Re: third gear wont work?????zzr 1100 1996
Sounds to me like you have got rid of the teeth off No 3 gear? I had a zzr that i worked on once and done the same thing(light throtle sweet but any more than that it just sounded shocking) and no power at all because it just had enough teeth to let it go on very light throttle but once under power it went bad.Its only a guese of what i have seen.
life starts at 200 kph!
- dickfaber
- Bike: ER6
sounds like the engagement dogs are rooted
had a suzuki 900 that had rooted dogs on 1,2,3. sounded like it was jumping teeth under heavy load, but was sweet under partial
meant split cases and new gears and all engagment dogs machined (undercut) by a machinist
heres a link that explains it http://www.aperaceparts.com/transmissions.html
- Strika
What he said
- Bike: ZZR1100
I don't wanna buy factory if I can get stronger race gears I d much prefer made in Aus???as for striker your comment don't much help so unless you have info regarding My problem don't bother.
I think skrika was just backing up what the other guys said that it's damaged teeth in third gear.P Broderick wrote:I don't wanna buy factory if I can get stronger race gears I d much prefer made in Aus???as for striker your comment don't much help so unless you have info regarding My problem don't bother.
- dickfaber
- Bike: ER6
not teeth, its the engagement dogs, actually open and read (you never know, you may learn something)
- Strika
1. It's Strika can't you read?P Broderick wrote:I don't wanna buy factory if I can get stronger race gears I d much prefer made in Aus???as for striker your comment don't much help so unless you have info regarding My problem don't bother.
2. Refer to Jmac's post as to if I was helping or not.
3. You've made 5 posts and want help, enemies are not what would be beneficial for you in here I wouldn't think.
5. I've rebuilt two or three ZZR boxes when working at Kawasaki.
6. Probably would have helped with some additional tips on the rebuild had you not been a dickhead.
7. I hope it's grenaded itself into a million bits and costs three time the bikes value to fix!
I actually thought they were called dog teeth,didn't realise it was a big deal. But thank you I did learn something.......dickfaber wrote:not teeth, its the engagement dogs, actually open and read (you never know, you may learn something)
- Bike: ZZR1100
Wow striker that took some effort! If your so wise & knowledgeable with your 2/3 rebuilds wouldnt it have been easier to state a remedy instead of talking yourself up!you obviously measure yourself by the amount posts you submit...bravo..your thin skin & weak threat of making enemies on here tells me that this site is Over run with weak opinions from people like yourself & that it's not worth the headache.!!! On the other its hand it's easy to mouth off to someone on the computer... You are pissweak.from the link dickfaber sent thanks mate gears are on the way over.
Hey, don't put us all in the same bin as Strika!P Broderick wrote:Wow striker that took some effort! If your so wise & knowledgeable with your 2/3 rebuilds wouldnt it have been easier to state a remedy instead of talking yourself up!you obviously measure yourself by the amount posts you submit...bravo..your thin skin & weak threat of making enemies on here tells me that this site is Over run with weak opinions from people like yourself & that it's not worth the headache.!!! On the other its hand it's easy to mouth off to someone on the computer... You are pissweak.from the link dickfaber sent thanks mate gears are on the way over.
- dickfaber
- Bike: ER6
winning freinds again strika?P Broderick wrote:Wow striker that took some effort! If your so wise & knowledgeable with your 2/3 rebuilds wouldnt it have been easier to state a remedy instead of talking yourself up!you obviously measure yourself by the amount posts you submit...bravo..your thin skin & weak threat of making enemies on here tells me that this site is Over run with weak opinions from people like yourself & that it's not worth the headache.!!! On the other its hand it's easy to mouth off to someone on the computer... You are pissweak.from the link dickfaber sent thanks mate gears are on the way over.
- Strika
You served mate, I just returned. I'll say it to your face if ever we meet. Been on here since 05. Never said anything in here I wouldn't say to someone's face. Those who know me will attest to it. All I was doing was supporting what was obviously the issue and solution in order to add weight to the reply. That is all. In future, I will just butt out completely if you ask, as obviously you do not need my assistance. As for thin skinned, your response indicates that perhaps yours must be as thin as mine. As for this site being overrun with weak opinions, that's a really ignorant statement, as the collective knowledge in here is vast.P Broderick wrote:Wow striker that took some effort! If your so wise & knowledgeable with your 2/3 rebuilds wouldnt it have been easier to state a remedy instead of talking yourself up!you obviously measure yourself by the amount posts you submit...bravo..your thin skin & weak threat of making enemies on here tells me that this site is Over run with weak opinions from people like yourself & that it's not worth the headache.!!! On the other its hand it's easy to mouth off to someone on the computer... You are pissweak.from the link dickfaber sent thanks mate gears are on the way over.
At least I waited for 8 or 10 posts before I made an arse of myself!!!
P Broderick wrote:......Wow striker that took some effort! If your so wise & knowledgeable with your 2/3 rebuilds wouldnt it have been easier to state a remedy instead of talking yourself up!you obviously measure yourself by the amount posts you submit...bravo..your thin skin & weak threat of making enemies on here tells me that this site is Over run with weak opinions from people like yourself & that it's not worth the headache.!!! On the other its hand it's easy to mouth off to someone on the computer... You are pissweak.from the link dickfaber sent thanks mate gears are on the way over.......
I sense your time with us will be short P Broderick.
- Strika
Gos, I didn't have the heart to tell him that my bike has the same Gearbox
Certainly apppears to be a well balanced person though, a chip on both shoulders
