Can someone please point me in the direction of the ZRX 6 speed gearbox update.
Has anyone done it...if so what do you reckon of it???
6 speed 'box.
- Bike: Z750
6 speed 'box.
- Bike: ZX14R
Re: 6 speed 'box.
Same final ratios, so all it does is give you a closer ratio box.Stuzrx wrote:Can someone please point me in the direction of the ZRX 6 speed gearbox update.
Have a look at zzrbikes.com motors show up there from time to time.
Fred
Re: 6 speed 'box.
And that there is the reason I never bothered with that mod. If it lowered the final drive I would be all over it like a fat kid on a donut...........as long as donut man was nowhere to be seenFred wrote:Same final ratios, so all it does is give you a closer ratio box.Stuzrx wrote:Can someone please point me in the direction of the ZRX 6 speed gearbox update.
Re: 6 speed 'box.
I like the 5 speed box. One less gear to change. Bike is so smooth I have found I have done long distances in 4th on the highway accidentally.
Yeah I like Kawasakis.
- Strika
Re: 6 speed 'box.
Yeah, inless racing it, I can't see the need. Mine rarely got out of top gear anyhoo!!!bonester wrote:I like the 5 speed box. One less gear to change. Bike is so smooth I have found I have done long distances in 4th on the highway accidentally.
- Bike: Z750
Re: 6 speed 'box.
Hmmm ........Thanx for that guys.Didn't know about final ratios.It's just that after 13yrs of ZRX ownership,I'm
still reaching for a 6th gear!!.
- Errol
Re: 6 speed 'box.
In conjunction with the six speed there is an option of using the top gear ratio from a GTR 1000, they apparently run a taller top gear.
You can then lower your final drive ratio if so desired, well thats what I would do if I had the money & inclination.
I have always felt 1st is too high for crawling in traffic & yeah it needs a higher top gear, you could always use 2nd to launch if the final drive was a little lower.
As another alt, I thing it was "bigtire" on ZRXOA who did a limited run of top gear cogs with even more overdrive than the GTR, I beleive he made extra's over & above pre-order qty's & did have some left over, that was some time ago (ancient history even)
Back in Black 2001
1/4 mile Best MPH 129.47
Best ET 10.747
Best ET 10.747
